CC - mate i got same prob.......the seat belts wont retract properly........if u find out a good fix can u let me know! I'll have a hunt around myself...maybe its just the retractor thingy (my technical term :D ) has given up the ghost!
Mate just go the 5 point harness..... u got the seat for it lol
Ando
yeah my front seat belts also don't seem to wanna retract properly at times, althoug with a quick jab they normally work again, i'll prob get some new ones soon, thou also wanna know which ones fit, so can we confirm that only s13 ones fit, or also r32 ones?
R33 deviat have you tried giving the seatbelts a gentle yank? it's the way japanese seatbelt work, they are electronic, if you give them a ever so gentle tug they usually retract themselves,
same goes for you CC
try pressing the release button if it just happens occasionaly,
i was trying for 5 minutes to get the passenger seatbelt to retract once, then just pressed the button and it zoomed up, felt a bit stupid after that,
i dunno how it worked or if it was just coincidence?
electronic??
Cover the seat belt in silicon grease. You can usually buy these in spray cans from supercheap. Once it is covered in it wipe it off and presto it should work better. May need to repeat a couple of times to get it right but it should eventually retract like new. Also something else to note, silicon grease is good for windows that are a bitch to retract, simply spray it in the slides and wind it up and down until it starts to get better.
Mr Eps.....yeah man i do give em a yank, which works, but it just feels a little unsafe when ur driving and it isnt 'tight' around ur chest....doesnt take up the slack..... will try a few things mentioned here, see how it goes!
so you cover the whole seat belt from start to finish with this silicon grease?
i'm not totally sure how this will work but i'm guessing it would just make the belt slide through the loops easier with less friction, is that right? i thought it was the actual retracting mechanism that would be playing up...hmm...
Thanks for all the suggestions guys... I'd try that silicone grease stuff but my seatbelts don't wind cos they're old and my windows don't go up cos they fall forward, I think it'd be a bit hopeful in my case.
R32 fit?
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
