mmm the zed r31 challenge
your next day is the day after my drift day john
i think you should come out for  a drift mate!!!
and ill come to the UAS day and bring some slicks
jon make sure you don't leave the bonnet pins at home this time
  • Replies 133
First of all let me say hello to all the car enthusiasts here.
I was there in the other Commodore (silver one)
Was my first time at Oran Park and had a ball.
Let me tell you its an experience on its own just to hold on and try and predict what the auto box will do in the barge :)
Cant believe how many nice cars there were out there (and quick too)
Ill have to come out again and get some better tyres and practice on the playstation. :D
Next time Ill remember to take my beanie !
Thanks John and all the boys for a great (cold)day.
*John the master cylinder stopper you made worked overtime :)
Window in block, sounds nasty. You were revving the ring out of it on Sunday trying to catch my zed so I not surprised. RB26 blocks hard to get and we don't have any sorry, try Just Jap . We have plenty of VG30 blocks, indestructible never heard of anyone busting one of those, why don't you try one?
At least you went out with a bang and have the pics of the flames on the track, which the prices of just went up. Makes for a good story at least Jason. Will you be ready for Sep 25 for the Zed V GTR Cup?
Jason, you could just buy an RB30 block. I've got one in the 31. you could buy the motor and have the car for free.
Sorry to hear about the motor though. It will be back bigger and better :P
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
