If you want some cheapos Chris....I run Simex sm8000 i think they are. They hold up pretty well for me in the wet and dry. I was giving em a mild test before in the wet, and they were gripping well.....easy to control the throttle to bring on the wheelspin if thats your thing :D
They are about $120 each when i got mine in January...
Toyos are a good brand though.....
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1408420
mmm, they seem cheap enough
Darren, where yours 16's? What are the sidewalls like? They will be going on the front first up, and I don't want a squirmy tyre on the front, it feels like shit if its like that
Thinking of going 205/55, but as the rims are 7.5" wide, it will stretch them out a bit and give it a bit more feedback through the wheel. I have run 205 on the front before, and to be honest, it felt better than the 225's as they had less sidewall flex, and braking was just as good. They are much cheaper too!
225's are a minimum on the back, even then grip is marginal
RaseR - what are the sidewalls like on the 17's?
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409397
i had transpath something or other on my old car, they gripped well since the car was close to stock, so ok for the price.. a bit slippery in the wet though!
and i think they are quite soft, as mine wore out to the thread in 15000kms :P :innocent:
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409464
I had a set of those on my car for about 3 years and never had any problems with them. Good grip on dry roads, decent grip on wet roads. Had a few hairy moments with 'moderate' take offs at traffic lights in the wet and also with a car load of people though! But definetely good for that price.
"The internet? Is that thing still around?"
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409471
getting two on saturday, will post results
Its was either a Toyo at $165, a Falken 326 at $160, or BF Goodrich at $220
I think for the $100 saving over the BF's, they are worth a shot. If they have soft sidewalls, I'll just run them on the back!
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409824
Hey Chris,The sidewalls on the Toyo TSW have more curvature then my previous Kumhos which were squarer (note, I have 8" wide rims on 235s and run 32psi). They still seem to be relatively stiff though, with no more noticable flex then previously - I'm only running them on the rear though.
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409850
Yeah, my size is 225/50/16 all round. My front rims are 7.5" wide also. Dont really know if you can call em squirmy or not...they do me just fine in the dry or wet. I run them front and back. My last tyres were 205's on the front, and they feel the same as these 225's on now.
Agree 225's are minimal for the back.
I guess how much you spend depends on how hard you want to push your car then, eh Chris? :)
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1410475
Well, first impressions are very good
Only done about 300kms on them, all wet, and they are very good. Will post up results as they get a few kms on them.
Extremely quiet at highway speeds
Pretty happy, decent sidewall too, so they handle well up front
Chris
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1418389
Yeah, got the Toyo's
Went just for a front set, I hate buying a full set of tyres I have never tried before!
I want some dry weather dammit!! They seem really good so far, dry tests will be the key once they have a few kms on them
They seem to be a reasonably hard compound too, so should get a few kms out of them. Once they are scrubbed in a bit I will throw them on the back and see if they are worth getting for the rear. If they are I might get a set of Toyo Trampio's for the front, they look to be a really good tyre for the front
Will post up results!
Hows the 3L in the wet? Would be a bit of fun wouldn't it! I remember going for a lap around the block in the dry and it was pretty taily with the mech. diff in it. Mine is and it has half the torque lol!!
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1418852
Very interesting in the wet...your able to keep the revs down and still get some tractions...just putt away and let the torque pull :P Mechanical diff hepls traction though..much safer i think than my old viscous diff...
IF you like wet weather well....its damn fun and scary at times :rofl:
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1419413
  • 4 weeks later...
Well, about a month on these now, quite impressed!
Easily the best value tyre I have had on my car, getting a set on the rear in a few weeks.
Feel much better than the FM901's they replaced, very quiet too!
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1463381
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
