If you want some cheapos Chris....I run Simex sm8000 i think they are. They hold up pretty well for me in the wet and dry. I was giving em a mild test before in the wet, and they were gripping well.....easy to control the throttle to bring on the wheelspin if thats your thing :D
They are about $120 each when i got mine in January...
Toyos are a good brand though.....
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1408420
mmm, they seem cheap enough
Darren, where yours 16's? What are the sidewalls like? They will be going on the front first up, and I don't want a squirmy tyre on the front, it feels like shit if its like that
Thinking of going 205/55, but as the rims are 7.5" wide, it will stretch them out a bit and give it a bit more feedback through the wheel. I have run 205 on the front before, and to be honest, it felt better than the 225's as they had less sidewall flex, and braking was just as good. They are much cheaper too!
225's are a minimum on the back, even then grip is marginal
RaseR - what are the sidewalls like on the 17's?
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409397
i had transpath something or other on my old car, they gripped well since the car was close to stock, so ok for the price.. a bit slippery in the wet though!
and i think they are quite soft, as mine wore out to the thread in 15000kms :P :innocent:
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409464
I had a set of those on my car for about 3 years and never had any problems with them. Good grip on dry roads, decent grip on wet roads. Had a few hairy moments with 'moderate' take offs at traffic lights in the wet and also with a car load of people though! But definetely good for that price.
"The internet? Is that thing still around?"
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409471
getting two on saturday, will post results
Its was either a Toyo at $165, a Falken 326 at $160, or BF Goodrich at $220
I think for the $100 saving over the BF's, they are worth a shot. If they have soft sidewalls, I'll just run them on the back!
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409824
Hey Chris,The sidewalls on the Toyo TSW have more curvature then my previous Kumhos which were squarer (note, I have 8" wide rims on 235s and run 32psi). They still seem to be relatively stiff though, with no more noticable flex then previously - I'm only running them on the rear though.
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409850
Yeah, my size is 225/50/16 all round. My front rims are 7.5" wide also. Dont really know if you can call em squirmy or not...they do me just fine in the dry or wet. I run them front and back. My last tyres were 205's on the front, and they feel the same as these 225's on now.
Agree 225's are minimal for the back.
I guess how much you spend depends on how hard you want to push your car then, eh Chris? :)
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1410475
Well, first impressions are very good
Only done about 300kms on them, all wet, and they are very good. Will post up results as they get a few kms on them.
Extremely quiet at highway speeds
Pretty happy, decent sidewall too, so they handle well up front
Chris
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1418389
Yeah, got the Toyo's
Went just for a front set, I hate buying a full set of tyres I have never tried before!
I want some dry weather dammit!! They seem really good so far, dry tests will be the key once they have a few kms on them
They seem to be a reasonably hard compound too, so should get a few kms out of them. Once they are scrubbed in a bit I will throw them on the back and see if they are worth getting for the rear. If they are I might get a set of Toyo Trampio's for the front, they look to be a really good tyre for the front
Will post up results!
Hows the 3L in the wet? Would be a bit of fun wouldn't it! I remember going for a lap around the block in the dry and it was pretty taily with the mech. diff in it. Mine is and it has half the torque lol!!
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1418852
Very interesting in the wet...your able to keep the revs down and still get some tractions...just putt away and let the torque pull :P Mechanical diff hepls traction though..much safer i think than my old viscous diff...
IF you like wet weather well....its damn fun and scary at times :rofl:
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1419413
  • 4 weeks later...
Well, about a month on these now, quite impressed!
Easily the best value tyre I have had on my car, getting a set on the rear in a few weeks.
Feel much better than the FM901's they replaced, very quiet too!
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1463381
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
