Hi all,
Im looking at getting an 5sp R33 GTS-T soon, and am wondering what sort of mods will be required to get into a mid 13sec 1/4. By looking at the time slip registry, it would seem that around the 200-250 rwhp is required (150~185rwkw).
What sort of mods are required to produce this? Are the mods such as full exhaust from turbo back, FMIC and boost control (at what psi??) enough to get these times? The reason I ask is the car will be a daily driver, but I want it quick enough to have some fun on the weekends too.
The car simply wont be a straight line car either, the suspension will be set up for hills handling (low springs and new shocks, strut brace), so will this affect times too much?
Thanks for your help.
Lee
https://www.sau.com.au/forums/topic/76884-whats-required-for-an-r33-in-13s/
someone asked about that not long ago dude, i personally dont know but i saved the recommendation of parts someone posted up, they were:
" front pipe / dump pipe / hiflow cat / 3" turbo back probably $1400 ish?
the dump pipe and hiflow will give a good power upgrade as the stock system is
pretty restrictive. other cheap mods,
apexi safc $400 untuned
cold air intake kit $200
some wider tyres 245's 255's. $400 each
pineapple kit $150
pod filter with cold air intake $80 pod only
boost controller (bleed or electronic). - bleed $50 - elec $250 "
hope thats some help :)
  • 3 weeks later...
