Finally got the R home.
71,000 kms and in absolutely stock condition (even found a pair of eyelash curlers wedged in the drivers seat - a chick's car!).
Green plate arrives (hopefully) next week.
Now on the lookout for parts to get some serious mumbo ATW.
Looking forward to some cruises soon.
Cheers
Gav
https://www.sau.com.au/forums/topic/7689-gavs-r-arrives/
Yep - did recognise you at Global, but had to run as had to get the dealer plates back.
As to plans - heaps in store, but as always depends on cash flow.
First up will be decent zaust - all please keep an eye out for any used bargains.
Cheers
Gav
https://www.sau.com.au/forums/topic/7689-gavs-r-arrives/#findComment-112699
Guest meanman
Gav, do you mind me asking how much you paid for it.
And also Guys whats the performance like does the R32 GTR beat the R33 GTR .
Any way mate that is a nice car I WILL HAVE one of those one day, but for the moment i am still dreaming.
:P May be i will see ya around look forward to it.
https://www.sau.com.au/forums/topic/7689-gavs-r-arrives/#findComment-116552
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
