sorry pple just read the post about 4 below mine about 10 seconds after i posted this.. on exactly the same thing...
no need to send me nawsty replies now as i know im dumb.. :D
my anger made me type before i looked..
show the receipt for what you paid and pay the tax.
you should have known this and budgeted for it (and $65 customs handling fee).
I pay tax out of my pay every fortnight. I'm not happy about it, but got no choice. just like you now. Pay the tax, or dont get your gear.
Hmmm...bad luck dood....unfortunately you will have to pay the tax :D
So far I have been lucky with NENGUN, but have only bought relatively small packages so far (steering wheel, Fuel reg, Dump pipes), and all have been marked Gift.
However your situation has rung alarm bells for me as they were going to be my 'Exact' next purchase!
Their is a reason why the retail shops cost more to buy this stuff off as they pay Duty and GST on everything they bring in so why should you not have to pay for it.
Customs are cracking down on expensive items sent from overseas and under declared or sent as a "gift" as it is one of the oldest scams going, the official imports are spitting about the parallel importers and back yarders.
To show proof of payment they will ask for the TT to Japan or credit card payment which will show a lot more then $395, if the retailers you buy off Japan as that is all they are selling the bits at told you that you have to pay duty and GST you would go to the local performance shop and buy the bit.
It is pot luck getting pulled up or not as they flag the sender also a turbo is heavy and looking at a new turbo they would go $395 yeah right.
privacy hey, what if the boxes had hanguns or drugs or kiddy porn?
customs have a job to do, and that is make sure the stuff coming into our country is legal and that the taxes are paid.
I hate tax aswell, but as they say, there are only 2 things in life that are certain, and they are death and taxes
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
