hey guys just a quick question
can a rb25 garbox be bolted to a rb20
does anything ahve to be moddified or is it a direct replacemant????
cheers
mines screwed was going to get rebuilt but have heard rb25 boxes are tougher is this true?
matt
https://www.sau.com.au/forums/topic/76973-rb25-garbox-on-rb20/
well im talkin bout putting the rb25 box in a silvia that allready has a rb20
so i hope it lines up
as for tail shaft have heard rumours that the CA shaft and box where diff the SR oh well ill have to speak to a jap wrecker or something??!!
i don't know that they do or not, my mounts are about 2 inch's rearwards of the normal CA box mounts, but my engine sorta sits a bit lower and further back also.
I got RB20 box (was told it was 25, till i took it out) babow!
I can't see why they shouldn't fit, as VL's run basically an RB20 box, and VLT's run same as RB25 i was under the impression??
Have you looked into getting it rebuilt? If so can you give an idea of price and parts repalced?
Mine is holding in there ok after two nights of drag racing, a drift day and 8 or so track days with +215rwkws. Its still going well with good oil, so im thinking its up to the power ive got, but it is a 180,000km gearbox that did about 3,000kms of track work with the std turbo.
So basically dont want to go to the expense and added weight of an RB25 box if there is a viable alternative...but suspect ill end up with an RB25 box.
Roy,
Your running that Castrol 75/90 in your box?
I've used the above.
I figured the slightly thicker warm oil will help my poor little rb20 box behind the rb30.
For the first few hundred km's the box was actually perfectly silent again. Its gone back to its usual loud input shaft bearing noise.
Yeh Castrol Syntrax 75W/90
http://www.castrol.com/liveassets/b...90_B1278983.pdf
The box is the same old same old when cold...it never has been brilliant. But once i have done a few kms it shifts fine, and it does feel better then the Fuchs that was in there.
Funny thing is when at the track, and when it must be pretty hot, it shifts like a new box, and for the rest of the afternoon/home etc it shifts brilliantly. After it has sat overnight and its 100% cold again it reverts back to same old same old:(
So it would seem to be a bloody good oil, but perhaps suggests it never really get sup to the optimum temperature/viscosity putting around on the street...well for my g'box anyway
When cold I honestly found mine shifts a little better with the VMX 80 I had in there, it also had a tube of that Nulon G70 stuff so its not really a good comparison.
I have found that after a few changes it shifts like new again, no notchyness.
Lightened flywheels makes a noticable difference to high rpm shifts. I will definately be going back, BUT this time, one with a replaceable insert. The ceramic will rip a molly item to pieces.
Roy,
Here is a link that works,
http://www.castrol.com/liveassets/bp_inter...90_B1278983.pdf
I might try that oil in my box when i put it back in, had a tendancy to crunch into 4th (woulda thought 2nd or 3rd be first to get noisy).
On the topic what oil do you run in yer diff?
i guess my only prob with my box is it just doesnt like second
round rev limit and bot 500rpm before
that is all its just annoying trying to hold a slide then pop second and it s just like
"he ha hmmmm get in there you son of a bi........."
i lose all power cuz i have to come off throttle
same in a straight line im sick of making a come back in third cuz i cant grab second fast enough
it makes the car seem slow its like ppl are laughing at me (V8 tosses where i live)
till ill blow past breaking traction in third (eat that bogans)
but yeah i just wanted to know if they can replace rb20 boxes
if its cheaper to get rebuilt then i will but it dont matter to much because i have to take all engine and gearbox out as one anyway (damn silvia tunnel to small)
and innisane
dont worry to much bout weight
my car with 3/4 tank fuel spare tyre all interior only weighed 1220kg on the weigh bridge
a standard 180 with all HICAS and all options weighs nearly 1240kg
so 20kg in a box wont matter to much
cheers
matt
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
