  • 2 months later...
Hullo... recently imported 1990 GTR... is now complied but because south australian cops are not the nicest the whole thing has to go back to standard. Am looking for a STANDARD computer to put in her so she can be registered. Was wondering if anyone can help me as Ive tried heaps of different places and am a four letter word beginning with s out of luck.
There's a few other bits and bobs that need changing over still (even had to change the globes in the headlights) but I really need a computer.
Would appreciate any help!!
Thanks
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
