i was wondering if any body has had any problems setting up there blitz boost controller, my controller wont hold a specific figure that is entered in to the controller ive tried swapping the lines over just incase they were wrong but still the same. it aslo spiked up to 23.3psi the other day, the car is tuned for around that boost level but i dont want to run that figure every time i drive it its my every day car. i just want to get it sorted out asap before it goes even higher resulting in engine failure. The controller was hooked up by ice performance so it was defenetly hooked up correctly. My only other theory is that my actuators could 1.4-5 bar min and there isnt any way of going under that figure. If anyone has upgrade actuators on there 2530's could you please let me know how you control your boost, my actuators are garrett ones too not the hks ones. cheers guys
https://www.sau.com.au/forums/topic/77023-problems-with-blitz-sbc-id/
Have you set it up properly ?
Is it in wastegate mode or actuator mode?
manual or auto mode ?
If you have the instructions go through it and make sure EVERYTHING is set up right.
Personally I found that manual mode works better than auto mode.
Either way its a good boost controller so hang in there and hope everything works out for you. :)
ive tried auto, manual, ac and wg settings im not sure what else to do.
Either way its a good boost controller so hang in there and hope everything works out for you.  :stupid:
