hey there.
i seem to have a problem with my r32 gtst. engine mods are as follows: 3" turbo back exhaust, turbosmart bov, K&N pod. now heres my situation. when i put the bov on the cap that is suppose to cover the plumb back didnt fit so i left it as is open into the atmosphere. a couple of weeks later i put it on the dyno and it showed that it was leaning out. is this open pipe the cause? it made 125rwkw (i cant remember the revs). is this a low figure for such a car or am i just expecting too much? im also thinking about boosting, what is the max boost the stock turbo will handle while still operating at good effiency? also how much power can i expect from this?
thanks in advance
OLi
https://www.sau.com.au/forums/topic/77047-r32-gtst-leaning-out/
Ive seen the stock bovs start to vent at higher pressures when they are disconnected but not blocked. This would cause a rich, rather than lean stuation.
as predator said, if your return pipe is open then that would cause problems as it will suck air in after the afm.
so you left the return pipe open right?
a coke bottle cap or similar fits over it.
then use a hose clamp to clamp it on there.
did you get a lean dyno read out "AFTER" you blocked this hole?
125rwkw is about normal for a r32 with exhaust and pod.
I'm sure that if the return pipe is blocked and you went on the dyno, you will find a nice rich figure.
well think about it.
when the hole was open, it was sucking in air which wasn't measured by the afm.
the air that the afm measures, gets the right amount of fuel.
the afm goes.. "HEY ECU... I got x amount of air commin in to the engine.. Make sure you add the right amount of fuel"
the ecu goes "yeh yeh.. I got ya covered"
and there is peace on the planet "combustion chamber"
but then you go "I'll just leave this hole open... she'll be right mate"
so all this extra air sneaks in to the combustion chamber where the air and fuel mix and get exploded by the sparks..
but due to more air in there that the afm didn't know about, you have a lean reading..
this is all true.
if you listen carefully, this is the conversation that goes on in your engine bay.
ocasionally, you might even hear the afm go "nah *** ya.. I'm not playing today.. I can't be farked"
then the ecu gets upset and the car runs like shit..
true story
I like stories!!
hmm i think 125rwkw is a tad low for a 32gtst with a catback and pod.
yeh i got 135.7 rwkw with pod, full exhaust only ...
now i have bigger turbo, fmic, avcr to 1.0bar, apexi custom air intake / pod, and when boost kicks in hard ... it feels like dat my afm or pump is leaning out ... and sometimes the engine cuts out ... sounds like fuel cut ??? coz i dont have a fuel cut defender.
would an power fc solve my issues??
With a fuel pressure regulator you maybe able to tickle 180ish rwkw
GTR inecjtors go straight into rb20s (444cc), once tuned with the power fc and a bigger fuel pump then its just a matter of turbo choice and boost levels to determine power levels :)
Oh and grab a z32 afm as an rb20 afm will max out around the same time as the injectors, might as well replace both at the same time rather than going back for another tune to put the other one on later!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
