need to know how much oil goes in an rb20 gear box the bolt on the side is seized and hve tried everything to get it off
I did this procedure a little while ago, get around four litres of oil and you will be safe for sure, you will only need about 2.5. You fill until it comes out the filler hole.
getting the filler plug could be a prob as u say... maybe take it to a workshop and they could have a peice of metal welded to it to help get it out although could be a bit difficult on a gearbox, other than that im not too sure... sorry
there is a guide in here about changing gearbox oil on an R32, try in the tutorial section under user tutorials.
https://www.sau.com.au/forums/topic/77074-gear-box-oil/#findComment-1410715
I put 2 litres in and pretty sure our gearbox's are same as a vl na 5 speed and the book at supercheap said 1.9 litres.not sure which bolt your talkin about, if its the filler just fill it up from inside the car through the gearstick. VMX80 2 bottles is what oil i used plus a nulon additive something 70 there should be stuff in tutorials
good luck champ
https://www.sau.com.au/forums/topic/77074-gear-box-oil/#findComment-1410763
