  • Replies 345
I may have listed these before.
Tough rims!!
WORK MEISTER S1
17x8 +25 all round
114.3 4 hole
Dunlop Lemans rubber.
Excellent condition.
Closing June 16th
Hi, issit possible to get the similar rims and size for a gtr ? 18inch tyres are a killer for me. thanks
Charles, whats the tire specs on these bronze TE37's? and condition? and ball park figure to Melbourne to my door? Also will 10.5's fit on a GTR32? anyone know?
VOLK RACING TE37 suit GT-R
18x10.5 +15
closing June 21st
these are fitted with Yoko Advan Neova 265/35/18 all round
less than 1000k's of travel total.
9mm of tread left. these things are like new.
this is the ONLY imperfection on the complete set.
this set was fitted on a 33 GTR. I dont see why they wouldnt fit on your R32 GTR.
Check PM for price to your door.
Cheers
Charles
The only rim similar in design available at this stage is a set of Oz Racing 3 piece rims.
disregard the label on the hub. they don't suit Ferrari.  lol.
New set. Ex display stock.
17x9 +24 offset.
$2540 landed
I own a set of these wheels, except w/ silver centres not gold. some C#$T stole my centre caps. You wouldn't be able to get your hands on a set would you?
-Patrick
Super Advan Racing
suitable for GT-R
18x9.5 +22
bids close 18/6
hi mate,
I have these rims atm. I am missing one of the little centre 'medallions' ie. I have the big nut bit, just not the little medallion and it's circlip. Would you be able to source one for me? I would imagine there are heaps around as they are a pretty popular rim in japan.
Thanks,
Richard
Beer Baron,
they are a popular wheel as you know however, it will be hard to find a seller willing to separate the medaion fron the rest of his cap.
I have spotted a seller selling just caps. At the very worst, we may have to bring in a full set of caps. As i mentioned to ocean, once i locate some, i'll PM you with what's available.
this may take just a bit of time.
cheers :P
Danny,
no full sets to suit your car at the moment.
here is what i have found anyways..
a pair of 18x9.5 +12 with good rubber. bids close tomorrow on these.
i can organise an additional new pair with or without rubber to complete the set.
this will work out a little cheaper than purchasing a complete new full set.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
