MADGT4,
apologies for the earler quote.
ive just had a look at our prices.
the black LM GT4's were really only produced for the Nismo built R34 GTR's and only come in one size 18x9.5 +12.
their landed price is around the 5k mark in comparison to the standard ones being a good $900 less.
  • Replies 345
Hey there,
Have you confirmed the R34 GTR offset yet?
I want a set of 18 x 10s, not too fussy what they are. I need them for track tyres. My current wheels are getting a few scratches each time I swap the tyres for a track day.
Cheers.
Hey there,
Cheers.
R34 GTR standard wheel offset is 18 x 9 +30.
Although if you wanted to fill out the guards, you could go 18 x 9 +15. or 18 x 10 +22 :)
thanks GTTR34 :)
ricknismo, i have some 19x10.5 zero offset and some 19x12 zero offset intensives in stock.
they may be a bit too wide im guessing.
ill check out to see what is available with hi disc clearances on auction.
stay tuned mate.
Thanks for the info. Does the wheel get a deeper dish as the offset number increases, say +15 to +22 ?
cheers
its quite the opposite.
the less positive offset, the more dish in most cases.
some manufacturers tend to extend the inner hub of the wheel to determine the offset keeping the dish the same size on one peve rims.
multi piece wheels will have a bigger outer dish with a smaller positive offset.
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
