  • Replies 345
sure thing Rick.
we so require a 50% securing deposit prior to bidding/purchasing.
Once we have secured the product, shipping takes approximately 6 weeks to reach your door. Once they have landed here in sydney, we request final payment prior to sending the product to you via local courier.
TE37 to suit GTR
18x9.5 +12
tyres not included, neither are batteries.
bids close 21/6
estimated $2200 landed
Hi I'm after a white set of these in a 18 * 9.5 with a +22 mm offset, without tyres. They are going onto a R32 GT-R.
Could you let me know if you find any.
Thanks
Andrew
LM GT MAG
immaculate!!!
18x10 +20.
suit GT-R
closing 14th Aug.
The ultimate light weight wheel
serious buyers only
How much will these go for? What tyres are on them? What size tyres? How much tread? Are the wheels unmarked?
Work CR Kai
18x9.5 +20
114.3 5hole
RE55S rubber. ready for the track.
auction ends 13th Aug.
how much it cost land in melbourne
spec r,
not sure how much these will close at at this stage.
we are estimating these to close at a price that will see these landed in Oz for about $2300+
local freight from Sydney to Melb is $120 on top of the landed price.
Mik, ill pm you with what i know about those LMGT MAG's
Work CR Kai
18x9.5 +20
114.3 5hole
wanna ask can u try to get it in for me below 2k if possible i want to place and order and wanna ask how much life the RE55S can last for thx!
at this stage, providing there are no other bidders, yes they will land for just under the $2k mark.
I wouldnt suggest using these tyres on the city streets. They wouldnt be lasting long at all. although many people have been using semi's on the streets, it's their choice.
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
