ferni,
the LMGT4 is not available in 10", most BCNR33 owners opt for the 18x9.5 or 18x10.5.
Speaking of which.. only one set is available on auction at this stage.
These are new unfortunately and have a $3700+ landed price tag. The upside is.. these are the 05 limited edition.
  • Replies 345
In Stock now.
TE37 18x9.5
Two are 18x9.5 +12 fitted with Dunlop FM901 rubber with 6~7mm of tread. These are used and in good condition.
Two are BRAND NEW 18x9.5 +22. (NO TYRES)
Up to the buyer which pair goes where for best fitment.
$3460 take home.
Edited by JDMimports
I like those lmgt4, but not relaly interested in 9.5" wide...need 10.5" me and chris are after them for the same reason :)
Are those lmgt4 you posted above 10.5" or 9.5"? If they are 10.5 I'd be interested.
Btw it was me emailing you this week about the lmgt4 and 99B's just so you know theres not 2 people after the exact same thing. Well i guess there is - Scotsman as well :D
ferni,
the Version II as listed above are only produced in the 9.5 width.
youll be needing the standard LMGT4 which is produced up to a 10.5 wide.
These are near impossible to find on auction as a used set.
As mentioned earlier, we may have to order new.
  • 4 weeks later...
I'm still looking for either TE37 in 18 x 10.5 or CE28N in the same size. Second hand, gutter rashed no problem as I only need them for track rims. Happy to trade in my 18 x 9.5 +12 TE37s if that is of any interest to you guys.
Also, you have gone underground on the lower lip and mounting hardware for the Nismo front bar you got me. What's the story on that one?
Regards
Aaron
Regards
Aaron
Hi Aaron,
That is bizarre.
Emails and forums are checked daily. no news from you mate.
Anyways.. regarding your lower lip, we have purchased this for you weeks ago. This is well and truely on it's way to Oz on container as we speak.
Cheers
Charles
NISMO LM GT1
Suit GT-R
18x9 wide all round
SOLD to the guy in the back corner with the blue hat.
How much for these landed in Sydney?
Not white, or any other colour, but these exact ones?.............
Do they come in 18x9.5 aswel?
This set has been imported and delivered to the new lucky owner many many months ago.
The LMGT1 is not a current model anymore. The only way to find these would be on auction.
and yes, i do believe these were produced in a 9.5 version.
Do you know roughly what they would be worth on auction from japan?
Or how much were they sold for months ago? as they can only get cheaper from then......
Cheers
PM is ok for the price if you prefer
Cheers
That particular set was new and the delivered price reflected on that.
It is very unlikely that we will find new ones these days.
Obviously, used sets will have a lower landed price in comparison to new sets, auctioned or otherwise.
A ballpark would be somewhere around the $2k to $2.5k depending on condition, size and tyre wear (if tyres fitted)
cheers
Here is something that will definitely generate some interest..
BuddyClub P1 QF
These have been resprayed bronze at some stage.
18x10 +20 all round.
These rims are THE lightest rims on the planet in these sizes.
Forged and very lightweight.
Expect around a $2k ~ $2.3k landed price.
These will surely be of interest.
Nismo LMGT4
18x10.5 +15
fitted with S type RE55S semi comp rubber. 4mm of tread remaining
We can land these at a bargain price of $3500.
Auction can close anytime between now and the 24th March
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
