MADGT4,
apologies for the earler quote.
ive just had a look at our prices.
the black LM GT4's were really only produced for the Nismo built R34 GTR's and only come in one size 18x9.5 +12.
their landed price is around the 5k mark in comparison to the standard ones being a good $900 less.
  • Replies 345
Hey there,
Have you confirmed the R34 GTR offset yet?
I want a set of 18 x 10s, not too fussy what they are. I need them for track tyres. My current wheels are getting a few scratches each time I swap the tyres for a track day.
Cheers.
Hey there,
Cheers.
R34 GTR standard wheel offset is 18 x 9 +30.
Although if you wanted to fill out the guards, you could go 18 x 9 +15. or 18 x 10 +22 :)
thanks GTTR34 :)
ricknismo, i have some 19x10.5 zero offset and some 19x12 zero offset intensives in stock.
they may be a bit too wide im guessing.
ill check out to see what is available with hi disc clearances on auction.
stay tuned mate.
Thanks for the info. Does the wheel get a deeper dish as the offset number increases, say +15 to +22 ?
cheers
its quite the opposite.
the less positive offset, the more dish in most cases.
some manufacturers tend to extend the inner hub of the wheel to determine the offset keeping the dish the same size on one peve rims.
multi piece wheels will have a bigger outer dish with a smaller positive offset.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
