Stainless or factory exhaust manifolds, results inside.
Have heard good things about Knox and been in cars (not Skylines) with their carpet, fits well and seems to be of good quality.
It's pretty filthy. Same same. ie, fithy. The stock ECU has an amazingly good filter on the CAS signal.
I have a factory diff with nismo plates installed in it and I love it, it’s so quiet, it will chirp the outside wheel slightly if accelerating around a tight bend in the car park but zero banging or crashing like most aftermarket diffs do
Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again... I'm hoping the latter...
