Excellent condition 40mm aluminium radiator together with Samco Hose for R33 Gtst for Sale. Original location, no modification required!
It's perfect for track racing or serious driver. If you want photos, please let me know your email address.
Price: $500 (Original Retail Prices more than $900)
Located in Melbourne, local buyers can come and pick it up. For interstate buyers, you will be responsible for postage cost.
The Radiator is made by Race Radiator, a shop that is specialised in racing radiator.
I have been using it for the past 1 year. It works every good.
For pictures, do you know how to attach pictures here, or you can leave your email address, I can send it to you.
Cheers
Pat
[email protected]
Silly question but im imagining the R33 and R32 GTST radiators are simialr enough to be interchangeable with a tweek of hoses etc?
R33 and r32 radiator hoses are on opposite sides.... so u cant interchange them
i get all my cores from race. and u will be shocked on how good thay are, and so cheap......
a 40mm will have NO problems cooling a 300rwks car on the track....
i use 32mm's and have no problems at that power
super cheap price mate.....
pics please :rofl:
[email protected]
Yeah. For the size, the length, and height is exactly the same with original one as it's designed for R33 GTS-T. So no modification is needed just plug it it. But the width has change from the original 16mm to 40mm. So it will take more than twic e amount of water compared to the old ones. Also the material is changed to aluminium, as you can see from the pictures, so it can releases heat faster.
If you are currently boost up your car, or you are serious driver, and you love your babe... .this is a must for your car. With this radiator, you can run on 300kw easily.
I will ship it to everywhere, once the price is right. I will get a postage quote for you or you can organise your own. Of course, melbourne users can come and pick it up yourself.
That's exactly right. It works superb in summer. With the original one, man, I can feel the heat even inside the car.
yer rod makes wicked cored. SO underrated its not funny i was really really shocked on the build of these babys, and best of all the PRICE...
and yours... i dont understand why so cheap...
i sell Lots of rods cores thru my biz and never had one come back, i used them in all my mates cars and even mine wicked cores. and best of all its made local, keep the jobs here :rofl:
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
