Has anyone installed or used a APEXi S-AFC II SUPER AIR FLOW CONVERTER?                If yes how well do they work.   Is one worth getting?
Have a read of the thread on the Jaycar DFA & IEBC, the DFA is the same as an SAFC in result.:)
