Sideways Posted December 21, 2002 Share Posted December 21, 2002 Hi All Has anyone else had problems with the lock nuts coming loose on the Adjustable Upper Control Arms that JMS sell (for the front of a R32 )? The inner locknuts on mine keep coming loose... it's happened twice now and I have only had them fitted for a week !! Has anyone else got a set of them fitted? thanks James Link to comment https://www.sau.com.au/forums/topic/7714-adjustable-upper-control-arm-problems/ Share on other sites More sharing options...
meggala Posted December 21, 2002 Share Posted December 21, 2002 you talking front or rear sorry I'm a bit dumb with suspension stuff but I have doen quite a bit of work on mine recently Link to comment https://www.sau.com.au/forums/topic/7714-adjustable-upper-control-arm-problems/#findComment-112815 Share on other sites More sharing options...
Sideways Posted December 21, 2002 Author Share Posted December 21, 2002 Originally posted by meggala you talking front or rear sorry I'm a bit dumb with suspension stuff but I have doen quite a bit of work on mine recently opps forgot to add that important bit of info Talking about the front Link to comment https://www.sau.com.au/forums/topic/7714-adjustable-upper-control-arm-problems/#findComment-112819 Share on other sites More sharing options...
meggala Posted December 21, 2002 Share Posted December 21, 2002 havent had that issue I would contact cause its not supposed to happen or use some locktight cheers Link to comment https://www.sau.com.au/forums/topic/7714-adjustable-upper-control-arm-problems/#findComment-112820 Share on other sites More sharing options...
Sideways Posted December 21, 2002 Author Share Posted December 21, 2002 I rang them yesterday and they recon they havent heard of the problem before... I was going to try some locktight on them tomorrow and see how it goes... and if that doesn't fix it them they can go back and I will just have to make do with the pedders Adj. bush kit fitted to the std arms.. unless someone can suggest some other option (other than the UAS ones - as the review on AutoSpeed wasn't too favourable for their ones) Originally posted by meggala havent had that issue I would contact cause its not supposed to happen or use some locktight cheers Link to comment https://www.sau.com.au/forums/topic/7714-adjustable-upper-control-arm-problems/#findComment-112837 Share on other sites More sharing options...
meggala Posted December 21, 2002 Share Posted December 21, 2002 I went the pedders bushes my self they have done the job for me but you dont get as much adjustment cheers Link to comment https://www.sau.com.au/forums/topic/7714-adjustable-upper-control-arm-problems/#findComment-112845 Share on other sites More sharing options...
JMS Posted December 21, 2002 Share Posted December 21, 2002 Send it back to us so we can see if we can fix the problem if you dont have any luck with the Locktight. We havnt had any trouble with them yet so yours is the first. Regards Terry JMS Link to comment https://www.sau.com.au/forums/topic/7714-adjustable-upper-control-arm-problems/#findComment-112879 Share on other sites More sharing options...
Ait Posted December 21, 2002 Share Posted December 21, 2002 Ahhh...another one with the same problem. Trust me mate, I've sent it to Pedders countless times and those bloody arms seem ridiculously unrepairable (I hope not!). Mine squeaks like crazy still and I just had an updated kit put in today! Link to comment https://www.sau.com.au/forums/topic/7714-adjustable-upper-control-arm-problems/#findComment-112911 Share on other sites More sharing options...
Sideways Posted December 22, 2002 Author Share Posted December 22, 2002 Originally posted by JMS Send it back to us so we can see if we can fix the problem if you dont have any luck with the Locktight. We havnt had any trouble with them yet so yours is the first. Regards Terry JMS Cheers Terry Will do, But my biggest problem is that I am off on holidays wednesday night (and am taking the car) so need something in the car (and something safe) cause I will be doing a lot of driving (with my family in the car) so I am in a bit of a spot - need to fix it by wednesday.. Off to Tassie on the ferry, so cannot delay our departure With my old std arms in place I have almost 5mm play in both front wheels.. so they are not an option... If only you were in Melbourne... or me me in Adelaide... At this stage the only fix I can think of that I might have any chance of doing by wednesday is to go with the local pedders fitted kit (or maybe the whiteline one is the same I think) Unless someone in Melbourne would happen to have a couple of std upper control arms they can lend me for a couple of weeks?? regards James Ozdat Link to comment https://www.sau.com.au/forums/topic/7714-adjustable-upper-control-arm-problems/#findComment-113016 Share on other sites More sharing options...
