Hi;
I have a tapping/ticking sound coming from my turbo i am unsure what it means. could it possable be shaft play (and if so what is shaft play), i also have a fear that the turbo wheel is damage as i have been getting sparks out of my exhuast.
The sound can only be hear from outside of the car, i have not noticed it well driving only when i just start her up
thankyou
https://www.sau.com.au/forums/topic/77167-shaft-play-and-turbo-noises/
are you still making good boost or is it dead that will tell you if the exaust wheel is missing, but I am sure they just go bang not go slowly, and smoke, last thing take it to a machanic that you trust and ask them for an honest picture
thanks for the reply, no smoke, and still comes on boost as hard as it did in the beging, i didnt think it would be the wheel, but something is making ticking sound from the area around the turbo
Have you checked for shaft play yet..?
If there is play chances are Blades are hitting housing.
Mine made more of a screech when bearing wore causing excessive play(on HT-18 Turbo), blades were hitting housing, snapped bits from the ends of the blades, just wore others, burn marks on blades and housing, still made boost :D
Rip off the intake pipe and hot pipes from ya turbo and free up the front inlet snout, so ya can undo that also to allow access to the compressor wheel... grab hold of the center and see if it moves forward/backward... it should have a minute amount of up and down, but forward and backward and you can safely say its ready to or is farked out. The forward/backward slack can allow the turbine to pull forward when making boost in a similar style to a propellor causes forward motion, and contacts the compressor housing which has obvious results. Get onto it asap to check for any shaftplay cos it can lead to more drama's. I dunno why you'd be getting sparks out the exhaust tho i'd be strapped to work out what would cause sparks exiting the exist? Unless it was the fibreglass packing in the mufflers breaking down and burning up ?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
