hey people i need some advice,
i have a rb20det 5 spd in my S13 silvia....
tonight all of a sudden it started rumbling and it sounded exactly like a WRX boxer engine. it was making normal boost levels but the power felt lower and it was very lumpy!!!! i pulled over and had a look under the bonnet, when i gave the throttle a little twist, i could hear a sound like a hiss. i couldn't destinguish if it was an air leak or if it was like a squirting sound. (if you understand me?) but the sound was around the top of the engine where the intake pipe meets the throttle body. is this a common problem some people have heard? or will it be something to go see a doctor about???
after i stopped after and turned off the engine for 30 mins it was fine again. then it happened for about 5 minutes while driving home. what is thisssssss?????
any help would be appreciated.
https://www.sau.com.au/forums/topic/77208-rb20det-problem-wrx-sound/
Dead coil pack dude! Guarentee it. Take off the plug cover and unplug each one individually. The engine will run even rougher on each one. When you unplug the one that makes no difference you've found the stuffed one :D
Mine did this when I imported it and as soon as it got warm the dodgy one would fail.
good luck.
I had the same problem but it was a spark plug,the ceramic bit above the gap cracked and slid down to cover the spark gap.Everynow and then it would back to normal,must of been the comp pushing it back up etc.
So yer as baselinez said coil pack coz it's not sparking.
Also spray carby clean around the inlet manifold(where the top/bottom meets)join and see if the idle changes.Could be gasket or maybe just tighting of the bolts.
I have had this problem many times and had many reasons for it.
As mentioned it could be a faulty plug or a faulty ignition coil or module. It can also be caused by a leak in the inlet tract.
As you heard a hissing sound around the throttle area I would be starting there first and looking closely at the rubber joiner for a split.
And while you have the crossover pipe off may as well throw in some new plugs.
Its gotta be ignition.
Mine comes and goes just like that on my RB26. Seriously just goes into Rexy mode, then 5mins later, goes to GTR mode. (GTR is better by the way, hehe).
It has to be ignition, because if it was a cracked seal or something it would be more constant, I think mine might even be the plug going into the module, hope its not a coil pack.
will a dud coil pack come and go though? cause today the problem seemed not existent. but i bet it'll go on the weekend again. also just noticed my clutch is starting to get very slippery, so thats more money i have to spend. is the RB sound really worth it in the end??? i'm thinking maybe an SR would have been the better option :D
just like almost the majority of contributors on this thread, i say that it is you coils. get them replaced.
(quote:'m thinking maybe an SR would have been the better option ) believe me, the RB is way better!
Dude, its basically the only problem the RBs have and its just due to age. Yes with my car the problem came and went until it stayed stuffed for good.
Do the test and it will prove if its them or not.
You can't blame a slipping clutch on the motor type :D Its just one of those things. Stick with it, the RB shits on the SR. One dud coil is the only problem i've had on mine in 6 months since I imported it. Fix it and you'll be fine! Keep us posted!
lol that was what i was like too, i was like: "hey cool i sound like a modded WRX!" then i started driving like miss daisy and worrying about it hahahah but i enjoyed the sound but not the rumble through the car etc.
i will try to suss out the coil packs on the weekend, and get back to you's!
Anyone?
Can you tell us how to test each coil?
Because if its going to be a matter of trialing each coil being swapped over, it could take 3 months, as its inconsistant whether it works or not. So I'll swap one, then wait a week, then swap the next one, wait another week or two and so on.
There must be some way to test.
Like he said, just unplug them one by one, if the one you unplug is GOOD the car will sound even WORSE, so plug it back in and move on to another until you get to one that when unplugged makes no difference, that's the cylinder that's down.
But don't just assume it's the coil, pull the spark plug out and check it (is if fouled? clean it and see if things improve), swap a pack around and see if the dropped cylinder follows the coil, if not to loom could be damaged, etc.
If it's a dud coilpack buy a new one, or if you intend to run high-boost in the future maybe think about a set of SplitFires (~$650).
I say again:
This is relevant because the guy the started the thread and myself are NOT having the problem all the time, but would like to fix it before it comes an ALL THE TIME thing.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
