R33 1995 GTS-T M-SPEC MANUAL
*87,000km Genuine
*New Turbo
*17inch Wheels
*Bodykit
*SoundSystem
*Exhaust
*Turbo Timer
*Cold Air intake
*Blow Off Valve
Plus more
This car is very clean in/out
Please dont ask for pics as I dont have time to take any.
This car must go, looking for $14,000 However ANY OFFERS will be considered.
But please only GENUINE buyers! Dont have time for timewasters!
Car is located in Adelaide
https://www.sau.com.au/forums/topic/77249-r33-gts-t-5spd-black-15000neg/
Sounds like a good car. I wouldnt mind buying it but its way to far... Adelaide!... but yeah I would like to buy it... if only it was in Sydney... I would have taken it straight away. Sorry
ummm, i dont understand why someone wouldnt buy this for that price!!?? is their nething wrong with it? reason for change of turbo? or it must be auto?
hmm, good luck wit sale.
There is absolutely nothing wrong with the car
it is MANUAL 5spd
The turbo died for unknown reasons, i'm guessing the previous owner had the boost turned up too far as usually these turbos dont cause any hassels.
New Turbo has been installed and everything is now in fine working order!
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
