Sat Night Cruise (WARNING DIAL UPers)
  • Replies 80
Originally posted by tactic
our pics turned up pretty good ed!
considering we had no light
mine are uploading now!
yup...sucks how they turned it off :)
oh well...
hurry up and upload :O
EDIT: alot more to come but I CBF doing them....sleep then up for the dawn run :uh-huh: :mad: Pics from the dawn run tomorrow I guess :P
good stuff
i will have a Canon Powershot S45 very shortly with a 512mb CF card and a 32CF card..... mmmmmm hundreds of 4 megapixel pictures.....
Oh and a tripod.... and i bought this thing today, it's like for taking those low down shots.. it bolts to the camera likea tripod only its a tiny little swivel thing which keeps teh camera off the ground by about 1-2cm.... its wicked :mad: now i can take angled ground shots with time exposure and they'll come out perfect:D
Email -all- your pics from tonight to [email protected] and i will add them to http://skylines.pnc.com.au
Sadly my pics didnt turn out at all, dunno if it was the settings of my CyberShot or just me not knowing how to use it properly ... i think i'll stick to daytime photo's.
Awesome night guys was fantastic to actually meet the people behind the nicknames. Everyone was -really- friendly which i totally didn't expect. Would be great do it all again afew times throughout the holidays.
do you want just web quality? b'cos each full res shot is about 1.5mb :mad:
How friendly was Minh and that security guard eh? *shivers* :shake: :shake: :shake: :bahaha: :burnout:
Originally posted by BY BY
Your in trouble now yang...:Bang:
Ed: that invisible touch looks awesome - good work
I got big size of that so if you wanna get it developed at a kodak shop etc in A4/A3 size let me know :D
XCUZME: nah didn't open the open halfway through the shot at all :( Happy b'day dude! Hit the magical insurance 25?
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
