Hylomar aero grade gasket joining compound RRP Price (AUD): $50.00
Non hardening and non setting. Unlimited assembly time. Vibration resistant. Allows metal to metal contact. Resistant to combustion products, water, engine coolant, petroleum, lubricating oils, kerosene and fluorocarbon refrigerants. Seals surface imperfections. Withstands rapid variations in temperature. Flame, dust and moisture proofing properties 100gm Water and oil pumps, instrument inspection covers, cylinder heads and sumps. Coating pre-formed gaskets, weatherproofing motors and outdoor high voltage circult breakers. Inlet manifolds, timing case covers, oil pump joints, gearbox and transmission components, thread sealing. Gas turbines, water cooled generator, turbo vacum systems and any machined surface.
they come in 100g tubes like a big tube of tooth paste i purchaced a box in from a mate in england. i am selling fifteen tubes may be more depends on how much i use he he @ $15 free postage this stuff is definatly top of the line thats a clear huge saving
price drop price drop
https://www.sau.com.au/forums/topic/77277-aero-grade-gasket-joining-compound/
  • Replies 44
sorry dude these tubes are $15.00 deliverd RRP is $50.00 check it out if you don't believe me there is only a couple of places that distribute it in aus, and it's for that price of $50.00
so $15.00 is a dead set bargan
the stuff you buy for $13.92 at super crap is shit if you want to buy that go ahead it it will just let you down in the long run.
Haha I meant are you willing to sell me one tube for $13.92? Reason being thats exactly what I've only got left in my account. Don't get payed until next thursday and don't really feel like going out to the bank just to deposit $1.08 LOL.
inasnt yes metal to metal seals are the best for this compound i have done my rocker covers and have had no leaks at all
sorry ongsta it would be unfair for other people who have purchased from me at $15 a tube
isnt this the same as loctite #3 (or otherwise known as aviation cement)
loctite #3 is way cheaper and comes with a brush applicator
used on my rear main and on plenum no leaks
definatly not this stuff has an unlimited assembly time loctite has a hour set time pain in the arse for when you lost a bolt or something also having a set time reduces its life span
this stuff is approved by and meets rolls royce (spelling) stringent tests it is also approved for use in all defence airforces around the world definatly top of the line
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
