Sorry to dig up an old thread but it's all relevant :( I'm after the same set of plugs, but I can't seem to find any. I tried Coventry's on someone else's advice but they don't have any. I also tried ringing a couple of Mazda wreckers but they had none either.
Does anyone know where I can get them from in Sydney and roughly how much I should be paying? I'll try a few more wreckers in the meantime.
Edit: I'm going to try Findapart.com.au and see what happens.
Around $80 each is around average I guess. $100 isn't too bad. $50 is the "buy it now" price.
Update on my situation: I found a Commodore wrecker that has some plugs (for $5 each) but I didn't have time to get around there today. Maybe next week.
So they're not the same as Commodore plugs? Where do you get the "2 female pins" from? When I had a look a few days ago it seemed the pins on my clip are already approximately the right size and shape, just the clip was stopping them going on. So if I just remove the old clip and push the pins in, then silicon it up, that should work?
I did mine with pins I bought from Mitre10. I am not sure if the plugs are the same as Commondore ones. Use another set of wires approximately 3" long. Connect it to the new female pins. Test the resistance between the new terminals. If ok, squeeze silicon inside the injector socket and wait for it to dry completely. Connect the 3" long wire to the standard injector loom. You can choose to remove the old injectors plug or hide it somewhere. Preferrably water prove it in a tiny plastic bag. It is important to test the connectivity or it will be too messy to clear those silicon out of the way! Good luck
Originally posted by Clint32
Unfortunately there are a few different plugs, series 4 injectors are the same as GTR and rb20 ones, the series 5 ones are different, ive been told they may be the same as rb25 ones but i cant be sure they look similar on the fuel rail, anyone have any pics of some or some for sale.
Unfortunately the places im sure will have some are on holidays till the 6th so i may have to wait unless i can find some.
I doubt they are the same as RB25. I have seen those rx7 series 5 injectors. High impedance and top feed. If SR20 uses the same plugs as RB25 then they are not the same. The plug shape is slightly the same as the SARD 550cc injectors (oval). The 2 side grooves for the plug to slide in is slightly off tho.
Damn, I got off work early today and I forgot to go to the Commodore wrecker to see if they fit. I'll try to remember to go this weekend. My injectors look virtually the same as sil21jun's (but from that angle it's hard to tell if they're exactly the same).
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
