HYbrid Intercooler Sale
Hyrbid Intercooler for sale. Core size 600 * 300 * 76 mm End to End is 800mm. Bar and Plate design. Which is known to be better than tube and fin. Made in the same factory that the hybrid ones are and will test exactly the same the only difference is they dont have the hybrid logo.
Good for vehicles for up to 800hp.
Brand New
$450.00
Brand New
$450.00
350.00
pick it up tomorrow.
Ok I will correct you because you are wrong. These intercoolers are made in the same factory as the hybrid ones so they are exactly the same the only difference is, is that when they come to Australia they put a metal plate on the top which says Hybrid. But the cooler is exactly the same. Hybrid is just a company who puts a plate on them.
For example I can import a tonne of these coolers and put a stamp on them saying " Ice Coolers" Therefore people will think its a special brand callled "ice coolers". When they will be exactly the same as the hybrid ones.
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
