Do you want to have your hearing impaired ?
Do you like it when it feels like your ears are bleeding ?
Well if you answered "Hell Yer!" then this is right up your ally.
2 x Kicker (F12c) 12" Competition Class Subs in a custom enclosure.
The box is made from 3/4" MDF and is internaly braced and sound deadened. The box has been built to Kickers exact recommended specifications, it is divided in the middle to give each sub its own internal airspace of 1.75 CuFt and are both ported by a 4" tube port.
The box features a gold plated quick connection port for each sub on either side of the box which is connected by Stinger 10 gauge speaker wire & gold terminals. It is carpeted and both have a Kicker removable subwoofer grill.
Each sub is 4ohm svc (single voice coil) and is rated to take 400w RMS peak, or 200w RMS continuous.
The subs can be linked together to run off one channel.
If they are linked in parallel it will drop ohms to a 2ohm load so you amp has to be 1ohm stable.
If they are linked in series it will increase ohms to a 8ohm load.
The enclosure dimensions are:
Width = 31"
Height = 13"
Top Depth = 17.5"
Bottom Depth = 21.5"
The subs have never been run in a car.
When i brought them I ran a 4hr break in procedure which was done on a test bench and involved varying freq tone steps.
A very regretful sale .... $550
https://www.sau.com.au/forums/topic/774-kicker-subs-in-enclosure/
It was goin to go into my hx kingswood, but i didnt manage to get that far, im too fussy and i wanted to custom the boot b4 it when in, but i ended up giving up on the car after i found rust in the rear quarter panels.
Haha, Prank you remember aggess ago a guy in Sydney from SDU was selling a sound setup with 2 x 12 " MTX boxed subs, pioneer splits, etc etc .... and you were after the subs ? I was the guy who purchased em, but I still havn't tried fitting them in the boot :) Maybe today is the day !!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
