Ok how can I get over this?  :confused:
I drive my skyline daily... to work and back, so about 70km's a day, combined with cruising two days a week, and all in all, a decent number of KMs.
I'm all good when i'm driving it, but everytime I get out of the car, I sit at my PC at work and dream about mods... exhaust, suspension, turbo, power, tyres, ECU, having no traction in the first three gears, running 11s... i'm sure you get the idea.  I go to the extent of pricing EVERYTHING up, reading 50 billion threads about how my car would react to those mods, etc etc.
However... the problem to go with this, is that I can't afford any mods at the moment, haha.  How do other skyline others get over the need to mod their car? :)  I am progressively going insane, and the empty $4k credit card is starting to look friendler towards me!!!!
SELL DRUGS :(
ive set myself a limit i dont want to spent so much money on my GTST so at the end i dont want to say "GEEZ i could have just bought a GTR with the amount of money i have spent"
all i need is a few more hits and im done - I swear , I promise
Front Mount - boost controller - tints and thats it
maybe change my rims but thats it ;)
:) all too familiar...I had my car for a while (a couple of years) before I had the money to even think about putting some decent mods on. When my wallet was thin, i just waited out and found a few bargains here and there ;) that fuelled my dreams at least a little. Now that i'm earning a little more money I'm trying to decide where best for it to go (aside from the credit card :) heh oh well...all in good time.
Best of luck :(
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
