Hey guys
recently got my auto changed to manual, as some of you know
i recently noticed that my clutch pedal is engagin right at the end ( nearly when my foot is off the pedal) .
When i accelerate the engine revvs higher then what it should be doin, and only slowly increases speed. ( The only explanation i see is that the clutch is slipping a bit, but find it hard to find why that is, as its a brand new heavy duty clutch)
Where as from when i got it installed the clutch was engagin right near the floor.
the clutch slave cylinder, was weeping a dribble but was replaced with a 200b one, as there the same.
i was insured the the clutch is a brand new heavy duty clutch,
it has a machined flywheel, and a r33 gearbox.
i have been driving around with the manual for two weeks now, and only started doing this now.
I do know that changing between gears there is no crunching of gears AT ALL.
Would there be a chance of the clutch slave cylinder when installed, it wasnt bled properly?
Definatley the clutch?
Or somethin goin on with the pedal?
Whateva it is i wouldnt have a clue.
Also to let ya know every mod i have had done to the car i have had problems and gettin sick of the Shit. Another thing payin good money, hopefully knowing that it will be done correctly and a quality professional job.
Havin this happen a fair few times leaves me to the fella upstairs doesnt like me .
Is there anyone that you know of that are located in brisbane i can take it too that do a quality job, to get it checked and fixed.
Im gettin the car dyno tuned at F.I.S.T on the 30th , The reason im takin it too these guys are ,
they are close too me
havent been there b4 and seen some of the cars they have helped with
have a dyno dynamics dyno
125 bucks an hour which i thought was reasonable
I will see if the fella that did the conversion can have a look, but just seein if any of you guys have had this happen and know what it is. BUT i didnt want to as i have been goin back and forth for different problems a couple of times.
Any help will be much appreciated
https://www.sau.com.au/forums/topic/77409-manual-gearbox-issues/
definatly sounds like clutch slip.
did they bleed the clutch system properly?? did they clean the clutch surfaces before and during install??? are all components in the clutch brand new??? were the rear main and gbox input seal replaced??
cheers
Linton
i would be goin back telling them to take it out and check it cause well that sounds like a stock clutch...
'Generally' depending on the setup if the system hasn't been bled properly the clutch will crunch between gears and it will not disengage properly.
What did the gearbox come out of? Series 1 or Series 2 R33?
Reason being is the Series 1 are the conventional Push type clutch where as the Series 2 are a pull type.
With the push type it is IMPOSSIBLE for the clutch to slip due to a poorly bled system.
Series 2, I am unsure exactly how it operates.
I do however highly doubt your clutch slip issue is caused by air in the system.
The clutch is probably stuffed. AND OR you have a gearbox leak causing the clutch to burn and slip.
hey guys
my problem has been fixed, but who knows if it will stay like that.
I took the car over to the fella that did the conversion,
there was no free travel at all in the clutch pedal, and he adjusted it and check the slave cylinder.
as i didnt know, if it wasnt bled properly it would of been the opposite and crunched gears through changes.
So the slave cylinder was right, i think he did say that there was a bit of pressure on the clutch and loosened and adjusted it.
Theres no leakage from the gearbox at all, same with the slave cylinder.
Gear changes are smooth as and there is no slippage of the clutch at all NOW.
gettin it tune at fist on the 30th so hopefully everythings sweet as
Thanks for ya guys advice and help .
the problem is back again, its happened another time after my last post
and was adjusted again, but now its back
the other time was it was not even engagin and was right on the floor
heaps of free travel it was adjusted then now,
just after i got it dynoed it had no free travel at all and engagin an inch from lettin my foot off the pedal
seriously is pissin me off and not likin it, cause i havent even got the chance to go for a good run in it yet , and has been 4 weeks.
if anyone that could look at it for is or some advice cause its streesin me out.
some of the things i have been thinkin that it mite be is the slave cylinder being a 200b one.
wasnt bled properly being that there is still air floatin round in the pipes .
and keeps adjustin itself.
thas all i can think of and make sure this is looked at this weekend .
Thanks
if the slave is the only thing changed since it started stuffing up then its that but if not than its the adjustment under the dash on the pedal as there is a threaded rod that u turn and wind the pedal towards the floor so it then engages closer to the floor and can come further up if u get my drift...
bit hard to explain, but shit i had my gearbox (gtr 4wd heavy ****er) in and out at least 8 times thinking it was the clutch when it was actually the pivot arm on the gearbox was in the wrong spot and the pedal needed adjustment
hope u get something useful outta that :P
cheers
Brad
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
