anyone one know a good setting duty cycle for 1.2 bar .....and what duty cycle would it be? has anyone out there hav the similiar settings and as the revs go up the boost maintains its levels??
my stock actuator is 0.80 bar (hks turbo and adjustable actuator)
e.g. i want ..
boost / duty cycle
setting B to be 1.2bar / ???? <--- anyone know a good maintained setting?
also what does it mean ....
if the actuator release vavle (exhaust housing) is open ??? closed ???
open = releasing boost pressure
closed = builing up boost pressure ??
or is it the vice versa ???
pls help!
https://www.sau.com.au/forums/topic/77430-settings-with-avcr/
1. set boost to 1.2 bar.
2. set duty to say 40%.
3. go to the freeway.
4. second gear accelerate and see what boost you get to.
5. increase the duty 5% at a time repeating the 2nd gear runs until it hits 1.2 bar consistantly.
6. go up or down in 1% increments to fine tune.
but my stock boost is 0.80 bar ....as he actuator rod is adjustable ..
so how do i make the stock boost to 7psi ....??? should i do this b4 i set the new boost setting to 1.2bar ???
as the solenoid might think that im running stock boost ...which im not so every increments % of duty cycle i increase may increase by 10 % etc.. etc.. ?????
what do i do ???
If your actuator is set to 0.8 bar (11.75 psi) then that's as low as you can go.
To get 7psi you have to adjust the actuator.
I'm really not sure about half of what your saying and I don't know the answer to your open closed question either sorry. Can you tell us why it matters?
thanks ..
u see if i adjust the rod tighter then the valve is closed ... but makes the boost higher ... but if i adjust the rod on the actuator to loose ...the valve is abit opened and doesnt build up boost as quick in which i pressume will make boost to 7psi or sumptin .. but has hell of a lag ..
well from what i could remember if the valve for actuator is open then its just not piling up boost coz the valve is open ...but if its fully closed then its building up boost ..
you know how the exhaust compressor part of the turbo has two holes ...one is for the turbine ...and the other one is for the release valve which is controlled by the actuator ..
i hope this helps ...its just i cant make out the correct words ..etc ..
    • Nope, still smaller rear, put on the 4inch exhaust and picked up power everywhere, ended up just shy of 800rwhp.   Didn't seem to be hitting any walls either, so perhaps could have pushed for more but all maybes and the fish that got away etc etc.
    • Races cars don't care for VIN either...
    • This could be sold and shipped to the US for many gold pieces. RMS has no say in that. Ask various Western Sydney inhabitants how it works.
    • Ha ha ha, mine loves to spend, all on the dogs (they're our kids, and her spending would likely rival that of some people raising children!) the only benefit is, her spending is tax deductible as she runs a business in the dog industry 😛 The above all means she can spend race car budget quicker than I can. 😛 That and a lot of the things I want are very expensive, and I can be a bit "you want how much for that?!" And at other times overly impulsive. Or I start the w days of research, get to day 1.5 and get really annoyed that no one will advertise actual specifics and it's just marketting BS and I go "well, now I don't want anything to do with that now!" Also I hate paying lots of money for something I can make from $50 in materials. Then I get the shits halfway through making things and wonder why others who just buy parts have more fun... 😛
    • Their 240Z with the RB26 would be a real nice thing to have in a garage to come out for an occasional weekend cruise It's such a cool thing in so many ways Sadly, we have a blue 240Z shell that I walk past every day, just sitting outside a shed at work, it has been slowly disintegrating and falling apart into the ground for the last few years, the owner cannot be found, and I am unable to "claim it" I've been told by work and the RMS, the rust in the body is excessive though, and it has had most of the salvageable stuff, like panels, trim and switch gear stripped off it over the last year or two, work keeps threatening to put it in one of our metal scrap bins, I wish they did though, as it makes Mark sad walking past it
