Hi guys,
I'm thinking of buying an '95 R33 GTS-T, and have put a deposit down for one.
The car drives great but there is one problem.
There is a knocking sound coming from the rear of the car, like a dull thud that occurs regularly, like once or twice every 5 seconds or so.
The owner said that it could be the shocks that need changing but I want a second opinion. He also said it might be the muffler hitting the chassis...
I've asked around and my friend said it could be the diff, but we are not mechanically mined so I just dont know. Is this a common thing with GTS-Ts?
If it is the diff, how much is it to repair/replace? Is it the shocks? or the Rear wheel steering problem, since this car steers at the rear too. Could it be the transmission??
Please help, I dont want to fork out the rest of the money until I get your opionions/theories!
Thanks!!!!
https://www.sau.com.au/forums/topic/77454-knocking-noise-in-the-boot/
Admittedly no.. does make sense doesnt it
I will see if the owner will let me take it to a mechanic before i pick it up.
He claims though that he's had it all checked underneath and he doesnt know what it is but he guesses shocks
I was just wondering if this was a common thing for a '95 model
Too late,
I bought it, its in my driveway as I type :)
Its a Nismo kitted virgin white '95 R33GTST series 1
It still made the knocking sound on the way home. I know i'm stupid for not getting it checked out but dayem, its in such great shape inside and out, you could mistake it for being brand new right out of a dealers. Not bad for a 10yo car.
Tomorrow I'll check the battery, the jacks and and while its getting it oil changed I'll get the mechanic to inspect the shocks/bushes and joints.
On another thing, the power on this thing is phenomenal, and its a nearly stock except for the bodykit, exhaust and filter. It was wet tonight so when I gave it some gas in third gear, the next thing i knew the rear wheels broke loose and i ended up in the lane next to me and not knowing how i got there. Luckily no cars were there.
Mind you my last car was a eunos 30X so I will have to completely change my driving style.
I'm happy to call this forum my new home so I look forward to posting and reading here from now on!
A friend of mine who inspected it when i got home said its most likely the exhaust and its quite common for lowered cars to make knocking sounds. I'll just have to take his word for it until a mechanical inspection.
I can live with the knocking sound, its not that loud anyway its just a small annoyance, easily drowned out by the turbo whislte, induction noise and exhaust. I love it all, it has character.
You might find this amusing but I drove home with the side mirrors folded. I didnt realise until the halfway point, and had no idea to flap them out lol.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
