Hi all
Just curious to know if the TCS (Traction Control System) on the R34s are linked to anything important that will affect performance or driveability ?
Reason for asking is im considering getting a new forward feed plenum chamber but this will get rid of the TCS. So just like to know if it will affect anything other than losing the ability to switch TCS on/off ???
https://www.sau.com.au/forums/topic/77489-tcs/
With a new plenum you'll lose the TCS permanently. The TCS only operates an extra throttle body infront of the main one. This is so that it can close the throttle (and stop wheelspin) even if you've got your foot flat to the floor.
I don't know wether the ECU will pick-up the lack of this 2nd throttle body but my guess is that it won't! It will detect wheelspin still and flash the SLIP light but nothing will happen.
However, I always turn mine off anyway.
https://www.sau.com.au/forums/topic/77489-tcs/#findComment-1416883
haha yes mine is almost always off as well.
Comes in handy in the wet though :(
So the removal of TCS wont affect and ECU functions??
Ie it wont go into limp home mode or start acting funny cause it cant sense that second throttle body ?
Thanks Ian, may have told you this before, but I showed my mate your website and he loved your front bar and how you trimmed the top part of it to expose more of the cooler. He has pretty much gone and done the same thing. Ill send you some pics of it when its finished if you want ;)
https://www.sau.com.au/forums/topic/77489-tcs/#findComment-1416886
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
    • Actually No, I’m not as intuitive as u
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
