Well instead of going the expensive and painful route of pulling the dash out and replacing the heater element, seeing as mine wasn't leaking, and I'm a cheap lazy bastard, I flushed the element with weak caustic, and it worked!!!
I will write a how to in coming days if demand is strong enough, but basically it's as simple as getting 2 pieces of clear hose around a metre in length, connecting them to the inlet and outlet, obtaining a caustic based cleaner (or radiator flush!), and alternating between the chemical and water, until you get nothing but clean water flowing out of the element. just use a bit of common sense, ie backflushing, etc, and you should be set. Oh and try not to get any chemical on your paint work, or shiny alloy bits!
When you're flushing, it's a good idea to blow out the chemical/water with air first (I literally "blew" through it with my mouth, just wash off the top of the hose before you do this) as the chemical will react with water. Just how much, I'm not sure, but it's best to be on the safe side. Make sure you wash the crap off you until that soapy feeling goes away - that's the caustic reacting with the fat in your skin, making it slippery!
Anyhoo so after about 3 soakings with the caustic solution (0.5% caustic solution, dont use any stronger!) and a good blast through both ways with the garden hose, pulsing it by kinking it etc, until nothing else came out, and then flushing once more for good measure, the flow went from feeling like blowing through a maccas straw, to being able to put a bit less than full hose flow through it!
So it can be done!!! and still no leaks in the cabin, i'm stoked!
https://www.sau.com.au/forums/topic/77491-heater-element-flush-success/
correcto :-) but it's not necessarily the only reason... There is a flap in the heater box controlled by the climate control that diverts air to or away from the heater element. ATM it's not working... but the element DEFINATELY needed flushing
The best method apart from a new or reco'd core is to rig up a mains water hose and air compressor nossle that Y's into one pipe. Reverse flush and pulse the compressed air.
Water will fly out violently when the compressed air is pulsed.
This method has worked for me where rad flushes haven't.
Be sure to turn the ign. on and heater control on so the flap opens, otherwise you will not get flow through the core.
I would have to disagree with you there, I'm under the impression that water ALWAYS flows through the core, and the only thing that controls temperature is the flap diverting air to/away from the heater core. Unless there is some kind of valve attached at the motor end of the heater core hoses hoses, is there? That's for the '33 anyway, it may be different again on the 32's?
If you remove the hoses at the fire wall, all you are dealing with is the core, there are no valves between the inlet and outlet.
Yeah I'm not sure just how effective radiator flush products are, but I can assure you 0.5%caustic works a treat. I work in a chemical plant where the stuff is readily available, so it makes it a bit easier to get a hold of the good stuff! I soaked it 3 times about 10 minutes a time, then hit it with high pressure water, pulsing by kinking etc... the water was deep reddish brown during each flush, so it musta been doin something! by the final soak not one bit of debris came out, and the flow increase was huge!
Thats not the way it works with my 1992 R32 GTST.
If I don't have the ignition on and heater selected I cannot get any water to flow through the core.
It simply blows back at me and makes me wet. :(
VL Commodores are also the same as are EF Ford Falcons.
This is why many people say to turn the heater on when bleeding the head.
This was the experience I had with mine. Besides the point... There is no method of controlling water flow to the core apart from within the firewall some where as the hoses are simply that.. hoses that rununder the manifold etc..
I know this also as I have removed the rb20det and slotted in the rb30det, at the same time replacing all the heater hoses. A good $400 later. :(
Hit yours with compressed air and water and I you will get even more crap out. :P
My heater is so hot that you cannot hold your hand in front of the vents for long as it burns. :)
Also.. For others... When doing this with the R32's be sure to bleed the heater hoses via the T-piece attached on the top heater hose that runs along the firewall, WITH the ignition and heater on. The T piece is directly behind the inlet cam cover.
Failing to do so will cause overheating. Don't forget to also bleed the plenum. :)
I use an old radiator cap that I've drilled a hole in that fits perfectly a pump bottle lid that has had the white popper bit removed. I dabbed some silicone around the edge and forced it in. Nice and tight.
Cut the bottom off a bottle and screw it in and attached it to the radaitor. Keep the water level above the plenum and bleeding is very easy. ;)
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
