my oil pump stop working today , is it easy to repair  with the engine in the car , any ideas is helpfull.
nope its basically impossible to replace with the engine in the car, you need to take the sump off to take the oil pump off. And you need to remove the flywheel to remove the sump. And you need to remove the clutch to remove the flywheel. And you need to remove the gearbox to remove the clutch....you can see how this story goes.
And since you are doing all that, and presumably you had 0 oil pressure, then you might as well do the bearings at the same time. And get your crank checked to make sure its still straight.
Its a huge job, like Duncan said..
Also if your oil pump failed - I'd suggest you inspect the condition of the bottom end and head (bearings etc) because almost definately you will find that the motor has sustained damage.
I shut my engine off immediately as soon as I lost oil pressure (within 2 seconds) but it still sustained damage to the bearings.
My engine and clutch are coming out next week, so it might be an idea to do the oil pump aswell. Whats a oil pump replacement worth? I thought NISMO ones were pretty damm expensive, but whats a worthwhile replacement without spending heaps??
N1 pump is only ~500 trade from Nissan (its been a while)
Its a fairly big job thats the downside
If you're doing oilpump, you're not far away from pulling the whole bottom end out and at least inspecting it. At least that way you're getting an idea of how the motor is going (bearing wise etc) and can adjust your plans to suit.
Nope, once everything is disconnected it is very easy from there, just a standard engine crane works fine as long as the car isn't too high off the ground on stands in the first place. Takes a lot of work to get ready to lift the engine out tho.
And your other option is to take the engine out the bottom of the car....undo the tailshaft, front drive shafts and drop the front subframe, out comes whole engine and gearbox. Just lift the car off the engine using an engine hoist.
Yeah we just did it in the garage, although I supose it would be even easier with a hoist......good luck....not sure which is easier, we put it in over the top last time and was pretty easy but we've done it a few times now....
I've heard/read that taking the engine out the bottom is much easier/simpler but I'll need to take the engine out in the home garage.
THanks for the reply Duncan
We took the engine out of mine out the top, and will replace from the top as well
Just disconnect the gearbox first and it's not too hard ;)
Thanks Duncan, thanks JimiH!
Hi Lucien. No problems, but now I'm replacing those sills that were crushed I'm having the entire car painted. This means I'll be keeping her a long time and I'm keen to take the engine out and replace every hose I can get my fat little fingers on. I'll renew the pumps and will change the timing belt, even though it looks like it has already been done.
It doesn't HAVE to come out, just thought it might be easier to do so. I'd like to repaint the engine covers and the inlet plenum too. *shrugs shoulders* Just thinking out loud when the opportunity arose ;)
Mark
Did you end up doing your drive shafts Mark ?
I agree with Lucien, do all the gaskets while the engine's out.
I pulled mine apart and did headgasket, all other gaskets, new pumps etc ... definitely worth doing for peace of mind :rofl:
How do you know that your oil pump stopped working?
Maybe it's the oil pressure gauge that isn't working?
Maybe it's the oil pressure sensor that isn't working?
:rofl:
I pulled mine apart and did headgasket, all other gaskets, new pumps etc ... definitely worth doing for peace of mind :)
Yep, had the boots replaced. The Repco universal ones won't work. The OEM boot (passenger side iirc) has two 'scalloped' cuts to fit around other components. I ended up asking Paul (two.06l) to do it for me as he has the right tools. One of the Repco boots split when putting it on, the other one ended up becoming an inner boot. Moral of the story is use parts from Mr Nissan.
Re gaskets etc.: I still don't trust the engine. The paint is peeling off the inlet plenum and the ECU wasn't screwed in correctly. I haven't found any signs of an EBC but I'm big on preventative maintenance before I go asking the engine for more power. I'm planning on doing exactly what you've done JiMiH. Did you DIY?
(sorry about the hijack guys)
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
