  • Replies 41
nice to see you getting there simon, you must be happy to have starting to come together
Why you want to run so rich?
And i'm surprized that after upgrading to the 044 you are still having fuel troubles what is your next step to fix the fuel supply ?
The cams your running are 272hks Yes? what lift ,as i heard danny just snapped a high lift cam and it is not that uncommon that they do (bit of a worry)
And the million dollar question what is your target boost preesure once everything is running right?
Peter. I want to run it that rich just to have a bit of a buffer zone as i will give it a hard time and just want to make sure its safe. Id rather sacrifice some hp and just make sure it doesnt ping. As with fuel thats the most that pump is gonna give at those afr's. Fabs gtr went about the same hp with a single 044 so im going to use 2 with a surge tank . Cams it is using are HKS 272 272 step 2 10.2 mm lift which isnt huge lift as they go up to 11.8mm on some. . As for target boost pressure this turbo should be in its efficiency at 24-27psi so thats what im heading for. Also lift the limiter from 8k to 9k when it has a fuel system to support it.
