my dad bought an old hilux 4wd for about 3k and it needed a bit of work, which cost about 2k. It has your typical 4wd extras, spoittes, bullbar, suspension lift ect. Its bloody bulletproof. 380000 on the clock (and it looks like its been wound back) and still starts first time everytime. drags its ass abit but it has the goods to tow. not the most comfortable car (especially with three piled in) but if you were able to track down a duel cab it wouldnt be too bad. wouldnt want one as a daily driver though, no air con and lovely blue vynil. plus the cost of petrol is rediculous..oh well at least deisels use less fuel.
another idea would be a old v8 one tonner.
my neighbor has a black hq with no exhaust... damn its loud. hes so crazy, he does donuts in his paddock with it and thrashes the piss out of it. its so funny.
back on topic, an old falcadore would be the best bet to use as a daily driver.. old falcons are some of the ugliest cars ive ever seen
  • 5 months later...
ive towed with my R31 sedan (with its then NICS RB20) my mates HR31 GTSX with no problems.........suspension on mine is koni reds with king superlows all round....ride height did not change, was fine going down hills (i mean i took it easy as you would) and a bit slower going up hills..........
and its strange, i got a h/duty towbar for mine rated to 1500kg unbraked
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
