With much reluctance, I am putting my baby up for sale.
In the one year that I have owned it, this car has been showered with TLC, and is one of the best kept Supras you will lay eyes on.
History:
• Build date July 1998
• Rare Quicksilver colour
• One Japanese owner
• Auction grade 4
• Imported by me through J-Spec Imports in mid 2004
• Just under 70000 kms at time of import
• Currently 81000 kms
• Modifications – brand new aftermarket brakes, wheels, clutch, suspension, car security (detailed below)
• Services (detailed below) – one major service at time of import (timing belt, spark plugs, clutch, all engine fluids, etc etc), one minor service at 75000kms
• NO ENGINE MODS! Never boosted, raced, or abused
• Engine warmed up for 10 minutes before each and every run, and idled for 2 minutes before shutting off, to reduce thermal stresses on engine and prolong engine life
• All gear changes made before 3000 rpm to prolong engine life
• Washed every week, waxed every month
https://www.sau.com.au/forums/topic/77549-98-supra-vvt-i-twin-turbo-immaculate/
Aftermarket:
The following parts were all sourced BRAND NEW, and have been fitted to the car over the past year. URL links provided for more info on each product.
• Brembo Gran Turismo 4-pot brake caliper and 2-piece brake rotor system (front and rear) – NEW $7600
o http://www.brembo.com/ENG/Performance/Gran...nTurismoBrakes/
• Bridgestone Potenza RE050 RFT 225/40/18 (front) 255/35/18 (rear) run-flat tyres – NEW $2200
o http://www.bridgestone-eu.com/bfe/v/index....00000001667RCRD
• Goodridge braided stainless steel brake lines – NEW $500
o http://www.goodridge.net/
• GReddy/Trust Airinx II air-filter – NEW $120
o http://www.trust-power.com/04gracer/airinx_2.html
• GReddy/Trust aluminium radiator pipe – NEW $100
o http://edgetuning.co.uk/product.html?id=tr...y=radiatorpipes
• GReddy/Trust strengthened timing belt – NEW $200
o http://www.greddy.com/prod_extreme_timing_belt.htm
• GReddy/Trust Titanium exhaust – NEW $1400
o http://www.greddy.com/prod_racingtt.htm
• Optima Yellowtop battery - NEW $450
o http://www.optimabatteries.com/publish/opt...deep_cycle.html
• Racing Gear JTC’N1 V-Stage fully adjustable coilover suspension – NEW $3300
o http://www.c-red.com.au/parts/rg/suspensio...on.shtml#vstage
• SolAce Formula 1 Plus window tint – NEW $400
o http://www.sol-ace.com.au/images/formula_1.gif
• SmarTire tyre pressure monitoring system – NEW $600
o http://www.smartire.com/products/passenger/index.html
• TRD 320km/h speedometer – NEW $350
o http://toyota-trd.jp/en/strt/i_fullscale.html
• TRD single plate clutch – NEW $1200
o http://toyota-trd.jp/en/strt/d_clutch.html
• TRD swaybars (front and rear) – NEW $800
o http://toyota-trd.jp/en/strt/s_stblzrbar.html
• Work VS-TX 18x8.5" (front) 18x9.5" (rear) alloy wheels – NEW $3200
o http://www.work-wheels.co.jp/wheels/index/...s-tx/vs-tx.html
Major service at 70000kms (Castle Hill Toyota) - $4000:
• Change drive belt #90916-02310
• Change engine oil Toyota 10W-30 x 5 litres
• Change engine oil filter Toyota Z418
• Change engine coolant Toyota - Red x 9.3 litres
• Change diff oil Castrol 75W-90
• Change clutch fluid Motul Dot 3
• Change power steering fluid Dextron III
• Change fuel filter #23300-49195
• Change crankcase hoses #12263-46010 (rear)
• Change crankcase hoses #12264-46010 (front)
• Timing belt replaced (aftermarket belt SUPPLIED)
• Air filter replaced (aftermarket filter SUPPLIED)
• Spark plugs replaced (iridium tipped)
• Change transmission oil Toyota V160 X 2
• Change oil plug gasket #90430-12031 X 1
• Clean + check operation of PCV valve #12204-46020
• Change PCV grommet #90480-18001 X 1
• Change crank seal #90311-46001 X 1
• Change cam seals #90311-40020 X 2
• Visually inspect fuel lines and connections
• Valve clearances adjusted - inspect only
• Inspect steering linkages
• Inspect bolts and nuts on chassis and body
• Injectors cleaning - remove and replace + clean
• Install TRD single plate clutch (pressure plate
• and clutch cover SUPPLIED)
• New stock flywheel
• Flywheel bolts
• Snap rings
• Throwout bearing
• Pilot bearing
• Rear main seal
• Install TRD speedometer/odometer (SUPPLIED)
• Install aftermarket radiator pipe (SUPPLIED)
Minor service at 75000 kms (Scott’s Dyno Tune) - $500:
• Change engine oil Motul 300V 15-50W 5L
• Clean aftermarket air-filter
• Inspect and test brakes
• Inspect suspension
Standard:
• Twin-sequential turbocharged 3.0 litre 6-cylinder twin-cam 24 valve electronic fuel injection (EFI) BEAMS 2JZ-GTE engine with variable valve timing-intelligent (VVT-i)
• 4-way electric driver's seat
• 6-speed Getrag transmission
• Airconditioning/climate control
• Anti-lock Brake System (ABS)
• Driver's and passenger's Supplemental Restraint System (SRS) air bags
• Electric retractable mirrors
• Electric windows
• Electronic throttle control system-intelligent (ETCS-i)
• Four-wheel double wishbone suspension
• Rain visors
• Torsen limited slip differential
Location and Pricing:
The car is currently located in Newcastle, NSW, but I am down in Sydney approximately once a month.
The asking price is $44000, which a steal for a car in this condition - I guarantee you that the first serious buyer to see the car will purchase it.
Any professional inspection is welcome.
SORRY, NO TEST DRIVES!
I can be contacted by email at
[email protected]
or leave a message on 0417068664
Best wishes in your search for a great car!
Peter
** BONUS OFFER **
I'm going to include the original Volk GT-C wheels (as pictured above) in the purchase price, as well as the WORK VS-TXs that are on the car at the moment.
The Volks are worth $3600 by themselves.
There's already been a fair bit of interest in the car, so the bonus wheels are a bit of a deal sweetener.
  • 1 month later...
