I recently bought an R33 GTS 1993 model Skyline, On cold starts the revs rise up and down between 1000 and 1500 rpm for the first couple of minutes untill it is at operating temperature, it is also seriously lacking performance, i'm not sure whether it has been serviced properly as i am the first owner in australia.
anyone have any ideas with the cold start problem and maybe a checklist to get the engine running properly?
thanks
https://www.sau.com.au/forums/topic/77555-na-r33-performance-issues/
It is meant to idle at approx 1500rpm for about 5 min or so until the engine warms up. It should not fluctuate however.
I'd start by giving it a decent service. At minimum change engine oil, oil filter and air filter (or clean air filter).
Its amazing how much difference an oil change can make.
if you are the first Australian owner then there is a host of things that you can do to make it go quicker and more econmical extractors - mandrel bent - big flow cat- bigger t/body port and polish match inlets a rising fuel pressure regulator and some sort of engine management and maybe if you are really keen find yourself some cam gears and advance the timing a little this should see you add extra h.p and more importantly more torque in the low to mid range
did u import an R33? congrats.
by lack in performance what are you comparing it to? a couple people here have CA18 and RB20E R33 GTS... Check if you have one of them.
Pretty much what Greg said, and I'd do the fuel filter, radiator flush, spark plugs, gearbox oil, differential oil, brake bleed, new brake pads probably.
These are relatively old cars, so they need a lil more attention - and the peace of mind knowing that every fluid/filter is changed is good.
A dyno run would show if the engine is running ok too.
Eug
  • 1 month later...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
