164 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Well guys, I have a big dilemma!
I am seriously contemplating upgrading my car, a 1995 33 GTR Vspec to something along the lines of a series 8 Rx7 RS (280ps).
I can pick up the Rx7 for slightly more than my GTR is worth. It would be 5 years newer - my gtr is feeling fairly old compared to the newer styling out there.
The Rx7 would still be fairly quick, but would only be RWD in comparison to the GTR's AWD.
WHAT should i do ? :)
https://www.sau.com.au/forums/topic/77562-talk-me-out-of-buying-a-s8-rx-7/
  • Replies 70
I suppose the biggest problem is that ive only had it for about 6 months, and ive only just spent 3 or so k on it, and its getting tuned this week at croydon which is another $700 or so ?
Ideally I wanted to keep the gtr for two years and then sell it and get into property ....
Why on earth would you put a weak-low revv'n 2JZ in a S8 when you have a high power'd 13B Twin Turbo?
They are the most amazing engine's with HEAPS of potential.( requiring bolt ons)
And when it comes time for turbo upgrade on the FD you can throw anything you want on it and it will still be more responsive then a GTR with 2530's!
go the rx7.... with the proper care and maintainance they will last aslong as any other engine... let them warm up and cool down properly... there is alot of rumours about the engines, ive heard it from a mazda mechanic that they are a really good strong engine.
any engine needs rebuilds at 50000kms with the wrong driver punting it along.
plus its a newer car, you've got some time up your sleeve before anything major happens,
its something different, something awesome, gtr's are awesome... but my gtst looks like a gtr. goes similar to a gtr. the rx7 is a complete new world.
cheers
Linton
Get the FD. Who says they need to be rebuilt every 50000ks. Do you think anyone would buy one if a stock one out of the factory only lasts 50000ks? As it has been mentioned above, have an engine tuned wrongly, drive it at the rev limiter when cold, and it won't last.
When set up properly, and warmed up properly, proper fluids etc, they'll cop a beating just like the RBs. Just as some people thrash RBs for 200000+ ks, rotor engines last a while too.
In terms of performance, it depends what you mean by performance? Drag? Circuit? An FD will kill your gtr in terms of Drag AND Circuit work. I'd imagine that your gtr is mildly modded? so doing low 12s? The FD will do that easily. Furthermore, in terms of circuit performance, the car is about 300ks lighter. Can have a lot more power and response relatively cheaply. Weight is very balanced, unlike skylines.
FD is a very nice car. I'm not being biased, I do drive a skyline afterall.
Cheers
hmmmm :confused: i thought eveyone knew 2jz are far superior to rb series engines
sure they rev lower then rb's but they make more torque, power and are more bulletproof in stock form.
EDIT i realise now you meant compared to 13b..... nevermind then.
I'd say go with the series 8, at least its a newer car and they are a lot less common then the gtr is, plus they look better and handle better.
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
