Friday Night Cruise Sessions - Palm Beach & Pizza Cruise - 24/6/05
Its time for another Friday nighter people.
Due to the growing popularity of the usual meeting spot we will not be meeting at the Chatswood Archer St Carpark, instead the new and improved meeting point is as follows:
Time: 9pm for an 9:30pm departure
Location: Chatswood Chase Carpark - Lower level (Entrance off Victoria Ave)
Destination: Palm Beach via the Northern Beaches with a stop off for Pizza at Newport on the way.
Some things to note:
* We will meet just inside the entrance of the carpark at Chatswood Chase. Not onlly is there more than ample parking in here, but it is under cover and out of sight.
* If you have a 2 way radio, bring it.
* Heroes and drag racers need not apply, anyone who attends and decides to do burnouts, drive like and idiot, or do anything that attracts attention to the group will have their plates reported to the police. We have never had a problem with the Northern Beaches police and we have been doing this particular cruise for over 3 years, anyone that puts our reputation at risk will be told to leave.
Register your interest here :(
Cheers,
Nick
  • Replies 184
Nick,
Can't make it thought it was departure 9.30 like previous ones, have an exam on which doesn't finish till 8.40..............sorry mate
Aye~~my exam finish on Thurs~~hee hee
Yeah~~
make it 9:30pm or 9:00pm~~i finish work at 7:30~~~and i really wanna come~~
oh i m not quiet sure about the meeting place~~
it s that the 5 level carpark next to mandarine center??
if so , what coloar is the level??~~~
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
