Just wondering
do any of use guys do your own service
What exactly do use do,
ive done mine once ive only had my car for 3000k's
just wondering what should be covered
ive changed oil filter
fuel filter oil
ran injector cleaners
i replaced coolant
have i missed anything
or is it worth taking to a nissan dealership or something and getting them to do it??
https://www.sau.com.au/forums/topic/7759-servicing/
That's about all you can do from a servicing point of view. Spark plugs can be done (after you pull the top of the engine apart, find you have the wrong spanner, put it all back together, drive up the shop to get the right one, then get home and pull it all apart again)
If you're any good, you can do mechanical stuff (I've done a head gasket replacement), but it really is a pain to work on the engine. I reckon they should get the guy who designed the thing to come and do something like a head gasket, then they might get an appreciation for what they have created.
There are enough reliable people out there (and there's a few cowboys) who can work on Skylines (do a search) that you don't have to take it to a Nissan dealer.
https://www.sau.com.au/forums/topic/7759-servicing/#findComment-113583
    • My purchase experience was no where near as glorious as yours but still a significant moment in my life! Yeah that's a bit of a dilemma as to whether you bring it back or not!  Obviously a massive waste of time and effort to bring it back if you're only going to move there anyway!
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
