Hey I was just wondering if these power dips are normal for a standard computer?
I thought that it might be going into rich and retard mode. We tried setting it to 10 psi but the dips still remained, and we tried setting it at 13/14psi and it got 181rwkw.
Car is a 1996 R33 GTST
Mods:
3" Front pipe
GTR cat
3.5" HKS Cat-Back
K&N POD FILTER un-sheilded
GTR Intercooler
Bleed Valve set at 12psi
Do u think it may be getting too much airflow at 10psi aswell?
Any help would be appreciated
Thanks, Mike
https://www.sau.com.au/forums/topic/77612-r33-dyno-results-power-dips/
Yep the good old R33GTST standard ECU rich and retard strategy. If it's a manual then Power FC is the go, if it's an auto then SAFC, DFA or equivalent.
PS; I wouldn't be running the standard turbo at 12 psi.
wow that looks like mine but mine was a bit smother up top with mods at the moment being
3" dump and high flow cat
hks super dragger cat back exhaust
K+N panel filter
bleed valve set to 9psi
putting the cooler on at the moment then going to get it dynoed at different boost levels to see what happens with the afr at the moment it is running WAAAAAAAAAAAAYYYYY to rich i am not sure if my budget supports an pfc so i will prob just go with a SAFC and see how she gos.
actually thats a really good comparison graph. we both around the same peak but i make on avg 20rwkw more at each km/h interval. the stock dump pipe is my current restriction and getting that changed this week and gtr fuel pump going in
Hey buddy. My r33 is doing the exact same thing. Ive been told that if I get a power FC it will fix things as well, but for about $1600 fitted with tuning.. its a bit more than i wanted to spend. I've been told SAFC II should do a similar job too ($400+Tune), im currently looking at getting one. I heard PFC is better to get if you want to change turbos later on.
BTW these are my specs:
3" seperated dump/front pipe
3" highflow cat and stainless xforce exh
HKS Pod filter
turbosmart manual boost control (running about 12ish psi)
hybrid FMIC
so.. similar to yours really mods wise. Ive attached dyno sheet.. which is around the same 226RWHP is around 165kw@ wheels i think (correct me if im wrong)
Thanks for all of ur replies, do u think that if i drop the boost the car will actually run better, considering it wont be rich and retarding itself?
Thanks, Mike
yes. it wont be flipping out as easily until you get the PowerFC :(
well if you drop the boost just under the stock ecu airflow cut then it wont keep going into rich and retard mode so youll make probably the same power, but the curve will be somewhat normal instead of a yoyo like arrangement.
Same thing happened to mine on the stock ecu.... i put the boost down from 12psi to 9psi and the car made plenty more power and was a lot smoother to drive...
As mentioned above, get a PFC, although i only achieved approx 10rwkw peak power gain the car as so much more midrange you will be very happy with it.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
