Hi all just got one of these in my car and i am wondering if anyone has played around with the gain feature and basicly what will it do if i set the gain higher and lower thats all if ppl could help it would be great thanks
https://www.sau.com.au/forums/topic/77620-blitz-sbc-id-boost-controler/
The gain control just varies the rate of boost increase. If you set it so boost increases too quickly then it can overshoot the boost setting. If you have it set too slow then the tubby takes too long to spool up.
Here's a snippet from page 6 of the manual
GAIN
Ratio of 0-100
Gain controls the boost response. The high the gain setting,
the faster the boost response will be. Stock turbo charged
vehicles with actuator type wastegates will usually use a gain
setting of 5-15 percent. External type wastegates usually
requires higher gain setting.
WARNING - High gain setting might cause boost spikes.
OFF Note: Each channel can be set to each individual gain setting
I've got the whole manual as a pdf. If you want a copy then PM me your email and I'll forward it to you.
