Hi Guys,
I need a couple of bits. I'm pretty sure it won't matter whether they are from GTST or GTR, but it's for my GTR.
I need:
1 standard MAP sensor (it's the little black box that sits on the firewall, drivers side with 1 vacuum line going in and some wires coming out).
1 pair of sunvisors including the bits they clip into, and the screws to screw them in. I have a set that I borrowed of Duncan many moons ago, and I'm sure he'll want them back. I also had a very nice offer from Paul and Stacey for their set, but found that the clips were just as time consuming to get as the visors so I'm putting the call out again :(
I also would like a pair of the rear grab handles and their screws, but not too fussed about these bits.
please pm me if you have any of this stuff.
Thanks.
i will give them a shot, but I don't think it'll be cheap. :bendover:
surely there must be some people about with complete sunvisors etc? I see R32s being written off pretty regularly.
did you end up calling nissan about the visors???
im curious to see how much they are...
also just a point, the clips are annoying your better of using something else to attach them.
i would NEVER part with mine :rofl:
Mr Beer - when I was in QLD I went to a wrecker and picked up a sun visor for $30. Just have a ring around wreckers who have front cuts ... should be able to find a pair!!
i got a set of sunvisors from an r32 gts-t. make me an offer.
sounds good. do they have the two bits they clip into too? and the screws?
if so we can work something out.
also, I've found the map sensor :rofl:
hi folks, I still need these. Chef kindly offered me his but I discovered that they are a different type of fabric to my interior. mine is the soft fabric type.
Thanks
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
