New Stock Of Profec B Spec Ii And Turbo Timer (lots Of Function) Best Price! W/pics!!
NEW STOCK!!
BUY FROM A REPUTABLE TRADER IN THIS FORUM. YOU WONT BE DISAPPOINTED!!
CLICK HERE AND JUDGE FOR YOURSELF!!?
ALL PURCHASES COME WITH TAX INVOICE AND NO MORE TO PAY!
ABN 77 934 867 271
I accept:
- Direct Deposit
- Money Order
- Paypal (3.5% surcharge)
BRAND NEW TRUST PROFEC B SPEC II + ENGLISH INSTRUCTION* = SOLD OUT
BRAND NEW TRUST FULL AUTO TIMER + ENGLISH INSTRUCTION* = SOLD OUT
* English Instruction manual will save you a lot of frustration. Trust me on this.
-Based on the very popular B-Spec., the all new PRofec B-Spec. II's basic function to increase boost is as easy as the original, with an added built in boost pressure display and optional features like real-time, peak or last boost display (in either kPa or PSI).
-There are optional warning and boost limiter functions that can be programmed to offer much more control.
-The two presets values can be stored and are executed by a larger capacity inline solenoid valve.
-This unit does not require extensive programming and is ideal for low to high boost levels for single or twin turbos with actuator or external wastegates.
TRUST AUTO TIMER
It is compact in size measuring 8cm x 8cm and 2cm in height.
Comes in new casing model with internal flashing LED pattern.
It has several mode to measure speed such as
Attack mode indicator - to record 0-200m, 0-400m, etc.
Attack mode indicator - to record 0-100km/h, 0-200km/h etc.
Stopwatch mode - to record up to 30 laps from 0 ~ 9'59''99
Best lap time mode - indicated by "BEST" being displayed.
Speed warning mode
Your current speed (with 'real time' speed reading)
Able to automatically calculate and suggest the cool down time.
Perform as all important battery mode indicator and to display 'real time' battery voltage. Crucial for those with sound systems.
Optional sound mode (i.e. to turn the sound ON or OFF).
Incorporated with parking brakes and speed safety features.
GALLERY
GREDDY AUTO TIMER
GREDDY PROFEC B SPEC II
  • Replies 57
NEW STOCK!!
ABN 77 934 867 271
I accept:
- Direct Deposit
- Money Order
BRAND NEW TRUST PROFEC B SPEC II + ENGLISH INSTRUCTION* = $479 + FREE DELIVERY (AVAILABLE IN SILVER AND BLACK)
BRAND NEW TRUST FULL AUTO TIMER + ENGLISH INSTRUCTION* = $129 + FREE DELIVERY
TRUST AUTO TIMER
Speed warning mode
GALLERY
GREDDY AUTO TIMER
 Share
    • New dampening settings are much nicer or crappy roads, I've also noticed no difference when throwing the car around on smooth twisty roads In other news: Idle hands are the devils play things, or, more correctly, my typical while we're in there 5hit, and too much time on my hands with online shopping  Some new purchases for the 2.5 swap Fancy pants new 32mm triple flow radiator, because the old radiator is old and needs to come out for the 2.5 swap anyway Gates fancy pants water pump, because recommended with the new radiator  Plus a new silicone coolant hose kit,  because old hoses are old And a sump baffle thingo, because while I won't track the MX5, I'll probably track the MX5, maybe, probably......but, while we're in there anyway, as the FWD 2.5 sump needs to gets replaced with the RWD 2.0 sump, so, yeah I am loving driving the MX5 around everywhere, the poor old Bogan Cruise Ship hasn't really moved in months
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
