Hey guys
just got some stuff in my shed i need to get rid of
1. Standard r32 front pipe - 2.5" pipe with good heat shield
Offers
2. 2x standard dump pipe -
Offers
3. 3" Stainless steel front pipe - joins into standard dump however can be easily modified to make 3" front and dump by exhaust shop
SOLD PENDING PAYMENT
4. Set of four standard springs
Offers
Cheers guys - any offers acceptable
https://www.sau.com.au/forums/topic/77675-r32-gear/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
