Looks can be deceiving. It's supposed to be 20% less throw length, not shorter in length. But I believe it is slightly shorter.
U want a shortend shifter. Take an angle grinder to yours then weld it back together. U want to be able to shift quicker, buy one of these babies.
Ok, sorry for the confusion guys. It looks like this shifter is only for R33 GTST Boxes. So my appologies to all the guys with R32's that PM'ed me.
If your keen to get a hold of one thou. This is where mine came from http://www.justsr.com/forum/viewtopic.php?t=85
Tell greg your from SAU and should pass on a discount, as a group buy was done a while back and he surely made some cash from us.
I have been telling people that I will ship it for $10. So i'll make that open to everyone. Dont PM me asking for a reduction in price! This is a bargain IMO and i'm already loosing money on a new item. Thanks.
It did fit into the box and it did shift gears. However the throw length was not decreased and the bush on the end of the shifter would not stay on for some reason.
Also the shifter itself felt longer in length. I was told by Greg @ JustSR that at the time of this group buy there were not manufacturing short shifter to suit the RB26 Box. However they do have some 'new designs' now.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
