Hey all,
Came down for the dyno day, which was a rather good day if I say so myself and also put my car in on the dyno. This is the result I got on the dyno.
Now even though that was the lowest power figure out of the all the turbo cars :( , it seems too high for a stock RB20DET with catback exhaust and pod filter. Converted to kw it is 144rwkw which is about 5-10kw higher than what it should be. Now I don't know much about dyno results and after checking out the latest version of HPI, there RB20DET with the same mods as me plus a FMIC made only 145rwkw which is 1kw more than mine. How can that be?
One thing I noticed in difference between my dyno result and the HPI car is that there intake temperature was 19 degrees while mine was 45 degrees? Not sure how such a high difference in temperature could occur but could it have inflated my result to give an incorrect reading?
Can anyone clear this up for me and any comments from the hyperdrive guys would be appreciated.
Cheers,
Scott
https://www.sau.com.au/forums/topic/77714-uncanny-dyno-results/
Dynos differ depending on how they are set up.
The HPI one may not have been in shootout mode so I'd say those figures are close enough not to worry about.
Your 32 seems pretty healthy anyway which is always good to know.
The intake temps are interesting though. Was that taken at the inlet manifold or air inlet?
If you have a pod without a partition, the ambient temperature would increase the reading from the temp probe, and therefore change the reading. A higher intake temp gives a higher corrected figure.
If the temp probe is sitting against anything in the engine bay, you may get an over inflated intake temp - as the air coming into the pod is coming straight through the open bonnet.
By comparison, my intake temps were 26 degrees, but I am using a partition. The run was done within a couple of minutes of my car arriving from a long drive. Still somewhat interesting as the ambient air temp would have probably been closer to 12-14deg at the time.
This is a good example of the fact it is almost impossible to compare dyno figures 100% accurately. I am quite sure the air going into your car was not 20 degrees warmer than the air going into mine.
Dyno is for tuning - they give you a good idea of where AF ratios are at, how and where power is delivered and where there may be problems with the current setup. Peak power should be a guide only.
']dude mine made completely stock , bar an intercooler, 184.5 rwhp, so your power isnt bad at all
Not bad but how much of a gain would a catback and pod filter give? On top of that result? Because if it's a +15rwhp gain, we would still be be in the same problem again.
No not really, because then it would seem LOW not high for the mods you have.
End of they day a dyno is a tuning tool, next time you do a mod, re run it, and see what improvements you have made. Ken and Lumpy run a very professional show down there, so I doubt anything was done to make your numbers wrong
Im documenting every mod i do on antilag, so check the main site every once in a while to see what comes of it. Might give you some insight to what mods you could do yourself
Cheers
TJ
my car only got 226rwhp with similar mods :)
Only difference is mines S1 and ive heard its alot more spikey when more boost is added, it dropped 40rwhp towards the top end in one spike. Im going for a apexi power fc when i can get the $$ together to fix
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
